Old 06-16-2016, 20:03   #1 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Mt6572 imei
Hello who can tell me why program show that imei repaiar done but its the same.BB is ok.
Operation : Repair Security [ v1.49 ]
Wait for phone...
Phone found! [ 44 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 110100303034474530019D6509F252A7
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 110100303034474530019D6509F252A7
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0x5131DCAD63176833A573CA75032D9A3F
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 354501483852458
IMEI [01] : 354501483852458
Set IMEI [00] : 354501483853213
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 44 ]
Sync...
Repair done!
Done!
Elapsed: 00:00:49
Reconnect Power/Cable!
Old 06-17-2016, 01:15   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
As some time bb is not ok but it shows so first repair bb and then repair security... if still not solve write NV ram and repair... if stilll not then flash and see hope ur prblm will solve
Sent from my S_plus using Tapatalk
Old 06-17-2016, 17:30   #3 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Hello and another phone that log show complate but no results
May be I am doing imei repaiar note true
Operation : Repair Security [ v1.50 ]
Wait for phone...
Phone found! [ 44 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.3.2 on BBID : 0x84
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594812A1A74F038F1F
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xF98D36945AFDD49BB86B86F4CB2323F1
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 353163058073296
Wait for phone...
Phone found! [ 44 ]
Sync...
Repair done!
Old 06-17-2016, 18:09   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
*Extrasenses on holidays.
Old 06-17-2016, 18:22   #5 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Its note good.How I anderstand will be after 3 monts yes.Bat I need Your solution note extrasenses solution.no other solution that can be offer yes?
Old 06-17-2016, 18:55   #6 (permalink)
JayDi's Avatar
Member: 462970
Again : extrasense on weekends.
Start from Identify logs with full info. I have no idea what phones you trying repair at all.
Old 06-17-2016, 19:07   #7 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
1. 1st phone is china Samsung G920f imei is invalid,cpu is mtk6572 alredy 5days want repaiar imei but cant do it.
second phone imei have repaiar alredy if You can help please solve 1st phone imei
Old 06-17-2016, 19:10   #8 (permalink)
JayDi's Avatar
Member: 462970
If baseband OK - do Format FS. Run phone. Power it off. Repair security.
If not work - read modem config ( BPLGUI in extra tab ) and use with mauimeta, try repair with it.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.19261 seconds with 8 queries
