04-20-2018, 09:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | how to init prealoader doogee x10 blocké en boot brom Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.00 r1 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
04-20-2018, 10:49 | #3 (permalink) |
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Operation : Identify [ v2.00 r1 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
04-20-2018, 11:05 | #5 (permalink) | |
Freak Poster Join Date: Jul 2017
Member: 2739340 Status: Offline Thanks Meter: 74 | Quote:
04-20-2018, 11:15 | #6 (permalink) | |
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Quote:
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO20.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! | |
04-20-2018, 11:52 | #7 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Quote:
Good Luck | |
The Following User Says Thank You to gracy_elec For This Useful Post: |
01-29-2019, 13:32 | #9 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Infinity Chinese Miracle-2 MTK/Mediatek v2.04 Released..Try... http://forum.gsmhosting.com/vbb/f296...vated-2556648/ Index of pub/software/ |
