03-30-2015, 12:49 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | mt6572 or mt6589 Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D42005200536631AD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D42005200536631AD [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : mtk6589_wet_lca ProdModel : GT-I9500 Device : mtk6589_wet_lca AndroidVer: 4.4.4 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB3.MP.V1.8 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : MT6572, E01 HW : BENRUI72_WET_JB3_GPRS_HW SW : MOLY.WR8.W1315.MD.WG.MP.V4 MM : 2000.00.00 VR : 1.0 SN : 040101MT0123506292_145640 10 Security Info : IMEI [1] : xxxxxxxxx0 IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 35xxxxxxx21 done! Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
The Following User Says Thank You to nori2007 For This Useful Post: |
03-30-2015, 13:06 | #2 (permalink) |
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | read full flash Code: Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D42005200536631AD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D42005200536631AD [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : alps ProdName : mtk6589_wet_lca ProdModel : GT-I9500 Device : mtk6589_wet_lca AndroidVer: 4.4.4 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB3.MP.V1.8 Saved to : D:\flash\Phones\huawei\infinity\i9500\MT6589__ALPS__GT-I9500__ALPS.JB3.MP.V1.8__Android_4.4.4__20140311_123446.ispff Done! Elapsed: 00:12:46 Reconnect Power/Cable! |
03-30-2015, 13:10 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. CPU is as BootLog define. Scatter will be also with correct CPU. Reason of that - correct phone info showing ( as it defined on info in phone ) , which helps find correct firmware. |
