02-25-2015, 12:49 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | MT6572 write imei Any ideea? ========================= Start ========================= 25.02.2015 / 13:44:59 ================================================== ======= Card found: S/N Chinese Miracle II [MTK module] v 1.12 Start at : [25.02.2015 / 13:45:24] Operation : Check / Read Info [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420165C3D80341A9 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D420165C3D80341A9 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Finish at : [25.02.2015 / 13:45:36] Start at : [25.02.2015 / 13:45:45] Operation : Repair Security [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... |
02-25-2015, 13:28 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello , if it stuck more, than 2-3 minutes - that mean something wrong with drivers. Try reinstall them , if same - that mean this phone not supported yet. Soon will be added more methods of repair security for MTK SP phones. |
02-25-2015, 20:22 | #3 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | @decodari, i have same problems whit some phones...but solution: Only root Phone In the most of all process to repair secirity, phone no need root... |
