08-10-2018, 11:00 | #1 (permalink) |
Junior Member Join Date: Apr 2018 Location: Philippine
Member: 2828445 Status: Offline Sonork: Bunso360 Thanks Meter: 1 | CHERRY MOBILE FLARE S6 PLEASE HELP [DA_ERROR] : DRAM Configure failed! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : NOT INSTALLED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following User Says Thank You to 0028E069E4 For This Useful Post: |
08-10-2018, 20:19 | #2 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,639 | PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER NAND Flash : NOT INSTALLED eMMC Flash : NOT INSTALLED Initialize Memory .. DA possible reasons |
08-10-2018, 23:08 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Load attached scatter, missing files error will show - ignore it. Retry booting. Post results b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
08-11-2018, 22:28 | #6 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
saya menulis - bahawa selepas memuat ia akan memaparkan ralat, dan itu ok. hanya teruskan prosedur pengenalan p.s. sorry for non-English. b.r. ALex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
