09-22-2016, 20:59 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | MT6572__samsung__GT-I9060__GT-I9060__4.1.2__ALPS.JB3.MP.V1 firmeware need i need this firmeware version :MT6572__samsung__GT-I9060__GT-I9060__4.1.2__ALPS.JB3.MP.V1 this is the backuped scatter file: Scatter Load Ok , BaseBand : MT6572 , Project : mbk72_wet_lca , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : samsung Device Model : GT-I9060 Device CPU : MT6572 Device IntName : GT-I9060 Device Version : 4.1.2 Device Compile : 14/03/2015 08:02:11 Device Project : ALPS.JB3.MP.V1 Device ExtInfo : GT-I9060 Ready to Flash! i found a one on infinity support (0-CommunityUploads ) : MT6572__samsung__GT-I9060__GT-I9060__4.1.2__ALPS.JB3.MP.V1 But when i used the scatter file downloaded from support appears this info : Scatter Load Ok , BaseBand : MT6572 , Project : sanstar72_wet_lca , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : samsung Device Model : GT-I9060 Device CPU : MT6572 Device IntName : GT-I9060 Device Version : 4.1.2 Device Compile : 7/15/2015 12:56:49 PM Device Project : ALPS.JB3.MP.V1 Device ExtInfo : GT-I9060 Ready to Flash! Operation : Flash [ v1.56 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420159478607903B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420159478607903B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0x2D335B74B333FFD9BCFBB750CF778D1B INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : sanstar72_wet_lca , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! i think are not compatible , Pls help to find the compatible FW for this model Thank you |
09-23-2016, 08:21 | #2 (permalink) |
Member: 382783 Status: Offline Thanks Meter: 124 | Hello , Any can help by sharing this FW ( MT6572__samsung__GT-I9060__GT-I9060__4.1.2__ALPS.JB3.MP.V1 ) with this Scatter file : Scatter Load Ok , BaseBand : MT6572 , Project : mbk72_wet_lca , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : samsung Device Model : GT-I9060 Device CPU : MT6572 Device IntName : GT-I9060 Device Version : 4.1.2 Device Compile : 14/03/2015 08:02:11 Device Project : ALPS.JB3.MP.V1 Device ExtInfo : GT-I9060 Ready to Flash! Thanks |
The Following User Says Thank You to rafanachi For This Useful Post: |
