02-17-2017, 16:49 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | MTK module (CM2MTK) need this feature in Futur Updat please to select specific partition to write an read for for example : if user need to read protected partition (exp: protect1.bin or ftp.bin ....etc) and if an user need to write only partion system (system.img ....etc) if its possible in futur reply thinks great infinity team all days you have unic and infinity of feature. |
The Following User Says Thank You to rebainoor For This Useful Post: |
02-17-2017, 17:06 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: UFI-BOX+EASYJTAG BOX Age: 34
Member: 1934602 Status: Offline Sonork: 100.1649323 Thanks Meter: 482 | ..::Hello Team::.. ..::Hello Team::.. {~_~}::::::::::::::::::::::::::::::::::::::::::::::::::{~_~} My Suggestion Is Add Team Add ACI Q80 MTK-6580 READ & WRITE Add All HUAWEI MTK-CHIP READ & WRITE Add All OPPO MTK-CHIP READ & WRITE Add All MEIZU MTK-CHIP READ & WRITE Add All XIAOMI MTK-CHIP READ & WRITE Add All CHINA SPD-6810+6820 READ & WRITE ..::& Must Be All Barand BootLoader Unlock Support::.. |
The Following 4 Users Say Thank You to .::Mosh@rof::. For This Useful Post: |
02-18-2017, 00:17 | #3 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | @rebainoor, i'm pretty sure that this was the plan. They said that MemoryTool known from QML module will be also added into MTK module, quite possibly with next (v2?) update. Currently, you can read any partition you want if you read flash into ispff file and then open it with for example FTK Imager or R-Studio. From there, you can just export a single partiton to an image. Flashing a single partition back is also possible but you need to modify scatter file for partitons like protect1 or frp as they should not be flashed in normal conditions. Last edited by KrzychuG; 02-18-2017 at 00:22. |
The Following User Says Thank You to KrzychuG For This Useful Post: |
02-18-2017, 10:14 | #5 (permalink) | |
Member: 231728 Status: Offline Thanks Meter: 2,103 | Quote:
02-18-2017, 11:24 | #6 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | Yes, it is, see attachments. In fact, they do work quite well and doesn't require R-Studio to scan the file to look for partitons. You can then create a byte-to-byte copy of a single partiton with R-Studio or user export disk image on specific partition in FTK Imager and you'll have a single partiton to work on later. Then, you can edit and upload it back to phone if needed and if you have proper scatter file that allows you to flash with addresses etc. |
02-18-2017, 12:37 | #7 (permalink) | |
02-18-2017, 14:13 | #9 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | What settings you used to read flash? It may be device dependant but the way i do it is by selecting "Pack images", "Read Info" and "Read Extra Files", this should produce complete image into ispff file. |
02-18-2017, 14:20 | #10 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Bangladesh
Member: 2274875 Status: Offline Sonork: ? Thanks Meter: 298 | Yas Need All Brand MTK Bootloader Unlock Support... Bcz CM2 Was Called CM2 Is King Of The World So Why Still Many MTK CPU Unable To Unlock Bootloader Many More Thinks |
02-18-2017, 14:52 | #13 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | Not sure if i understand you correctly, but yes, it should take a longer while since it also include userdata. Depeding on the phone, output file might be even 32GB in size (or more if there's bigger memory chip inside). With current version there's no way to read a single partition so that's the option you have. You can, alternatively, use read flash option from SP Flash tool if you know partiton start offset, it's length and have scatter and preloader file thatn can be used with that phone. |
02-18-2017, 15:40 | #15 (permalink) | |
