02-13-2015, 10:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | tecno h6 unlocking here is the log 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142015924E6F3912D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 150100513758534142015924E6F3912D [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142015924E6F3912D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 150100513758534142015924E6F3912D [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Phone not support that feature!!! Operation useless Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
