Old 11-18-2017, 15:13   #1 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
OPPO A39 NEO 9S CPH1605 MT6755 FRP REMOVE Done
SUCCESSFULLY REMOVE FRP MT6755(OPPO A39 NEO 9S CPH1605)USB
Scatter Load Ok , BaseBand : MT6755 , Project : oppo6750_16021 , Storage : EMMC
Files found : 15 , Set to Flash : 14
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : OPPO
Device Model : CPH1605
Device CPU : MT6755
Device IntName : CPH1605
Device Version : 5.1
Device Compile : 9/14/2017 05:34:53
Device Project : CPH1605EX_11_A.11_170414
Device ExtInfo : CPH1605
Ready to Flash!
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 39 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from IDB!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GB
[eMMC] : FLASH_CID : 90014A484247346132A4552ADE4293AB
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0x35626C1B2CB1AFA35CD1F211312CC975
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
[AP] : Initial info read Ok!
Brand : OPPO
ProdName : CPH1605
ProdModel : CPH1605
Device : CPH1605
AndroidVer: 5.1
MTKxCPU : MT6755
MTKxPRJ : CPH1605EX_11_A.11_170414
SECURITY :
IMEI_SW [1] : XXXXXXXXXXXXXXXX
IMEI_SW [2] : XXXXXXXXXXXXXXXX
BTMAC Addr : XXXXXXXXXX
WiFi MAC : XXXXXXXX
EXTRA :
LCD : Not info available
LCD Res : M_HEIGHT=1280xM_WIDTH=720
TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX
CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw
CAM [1] : imx258_mipi_raw
CAM [2] : ov5695_mipi_raw
CAM [3] : ov5648_mipi_raw
MODEM : oppo6750_bc011
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 39 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear PVL ( PrivacyLock )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:24
THANKS INFINITY-BOX TEAM
The Following 9 Users Say Thank You to gracy_elec For This Useful Post:
Old 01-21-2018, 06:19   #2 (permalink)
sumatera's Avatar
Member: 756701
Sonork: 100.1592286
Thanks Meter: 91
please share secure boot for this type
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2122
EMICFG_NOT_ACCEPTED_CONFIG
Boot Error!
Operation Failed
Elapsed: 00:00:11
Old 01-21-2018, 11:08   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
Dear Sirs,
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Please do not upload password protected or damaged files, all of them will be deleted after upload.
Thank you !
Page generated in 0.15386 seconds with 8 queries
