09-19-2017, 09:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | wiko ridge fab 4g imei repair After flashing this wiko lost imei and wifi, any help? i read software from another phone. imei is null/null is it possible to repair ? before was ok best regards |
09-28-2017, 23:55 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Is baseband okay ? does it showing up under settings/about phone ? Is imei "null" after *#06# ? or some random numbers ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
09-29-2017, 10:48 | #8 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Install correct drivers Index of pub/software/drivers/ Then make read info |
09-29-2017, 13:33 | #9 (permalink) | |
Junior Member Join Date: Feb 2017
Member: 2689595 Status: Offline Thanks Meter: 2 | Quote:
4shared . com/s/fnw4g5SM2ca PASS: WIKORIDGEFAB THIS modem file 4shared . com/s/fNL7okO4Qei. Last edited by agungpanutan; 09-29-2017 at 13:39. | |
09-29-2017, 17:48 | #11 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Quote:
Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 08270E86 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 03E59F67D65C49442318F8E52279F9D1 ID_BLOCK_L : E2913F8E8312BCC9CC2B6CA5AF46507B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : WIKO ProdName : l5320 ProdModel : RIDGE FAB 4G Device : l5320 AndroidVer: 5.0.2 Manufact. : WIKO SysPatch : LRX22G DevComTime: 10-05-2016 05:52:20 QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:32 Reconnect Power/Cable! | |
09-29-2017, 18:24 | #12 (permalink) |
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Try to write that with securityOP button via EDL mode https://yadi.sk/d/A1KEaQQI3NLDD7 then let see result |
The Following User Says Thank You to vasko_bojilov For This Useful Post: |
09-29-2017, 20:01 | #13 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Operation : EDL Security Operation [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! theres no opcion to write that file...only backup...restore and wipe... |
09-29-2017, 22:05 | #15 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | ... guys, before continue, try to use factory updater, lets see if after update baseband will return. From that point, imei fixing is trivial. Download factory updater - HERE p.s. After starting updater, it will self-unpack, and in that unpacked folder, there will be ROM folder, with factory ROM package. FSG (EFS) partition is present in it, MODEM, etc. b.r. Alex
