Old 05-05-2016, 20:14   #1 (permalink)
Member: 56090
Thanks Meter: 162
MT6575 : Load File Bad file detected!
Have two set samsung i8190 mini mt6575 android 4.4.4 one keep restart and the other is ok then i read full flash MT6575__SAMSUNG__GT-8190__JRO03H.I8190XXALJL__Android_4.4.4.ispff but when trying to flash it in the bad set program mtk module 1.47 display Load File Bad file detected!
any help from support
Salam
Old 05-05-2016, 20:33   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Read scatter file by ticking both option,read firmware. It will work
Old 05-05-2016, 20:36   #3 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hi,
I think it is nand nand writing is still not support in cm2,,, plz read scatter file frm working phne in cm2 and write to fautly phne with sp tool
Sent from my S_plus using Tapatalk
Old 05-06-2016, 22:14   #4 (permalink)
Member: 56090
Thanks Meter: 162
Before i post , i try to do all supposed action to succeed resolving problem, what you supposed to me i have done on first try but cant read firmware with scatter not supported in cm mtk "too old device, FW reading not supported"
Chinese Miracle II [MTK module] v 1.46
Start at : [20/04/2016 / 15:16:45]
Operation : Read Flash [ v1.46 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x008A , [HYNIX] H9DA4GH4JJAMCR_4EM
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/01
DEV RID : C15C4407412C8FD58CCBF7DD0023BC27
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Too old device, FW reading not supported!
Salam
Old 05-10-2016, 18:21   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
It is old NAND device.
I found just one, so can't make any working update for them.
Page generated in 0.14252 seconds with 8 queries
