m.aminhaqjoo | 03-09-2016 07:17 | MT6575 NAND FORMAT NOT DONE with V1.42 Here is the log, and I could be able to format with V1.40 Code:
Operation : Check / Read Info [ v1.42 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x008A , [HYNIX] H9DA4GH4JJAMCR_4EM
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/01
DEV RID : 92D58745EEAF36DBD3F4B0F8E278A816
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:05
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.42 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:19
Reconnect Power/Cable! |
