03-23-2017, 13:28 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: pakistan
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | mt6580 nand not supported...gfive gpad 706 plus 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0053 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/00 DEV RID : 0x4A1EA44D245C8F493AE06EB9EA1D023A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info! Make "Identify" first! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
03-23-2017, 13:35 | #3 (permalink) |
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 22 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0053 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/00 DEV RID : 0x4A1EA44D245C8F493AE06EB9EA1D023A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Error] : Bad PRELOADER data Looks like unusable file , break! Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
