02-26-2017, 14:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Pakistan
Member: 2276949 Status: Offline Thanks Meter: 160 | MT6580__HOTWAV__Venus_X10__d8058__5.1__ALPS.L1.MP6 .V2_SUNV6580.WE.L_P11 Same Blue Display If Anybody Has Tested Factory File Or BIN File Kindly Share If You Do not Want To Share For Free I Will Pay For File PM Me Thanks Code: Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : HOTWAV Device Model : d8058 Device CPU : MT6580 Device IntName : full_d8058 Device Version : 5.1 Device Compile : 4/22/2016 5:42:44 AM Device Project : ALPS.L1.MP6.V2_SUNV6580.WE.L_P11 Device ExtInfo : Venus_X10 |
The Following User Says Thank You to Khan Bhaie For This Useful Post: |
03-01-2017, 11:24 | #3 (permalink) |
No Life Poster Join Date: Mar 2007 Location: mamukanjan PAK
Member: 476792 Status: Offline Thanks Meter: 152 | MT6580__HOTWAV__Venus_X16__d8058__5.1__ALPS.L1.MP6 .V2_SUNV6580.WE.L_P11 you need this file |
The Following User Says Thank You to muzamalshahzad For This Useful Post: |
03-01-2017, 11:33 | #4 (permalink) | |
No Life Poster Join Date: Jan 2012 Location: Satkhira khulna Bangladesh
Member: 1716947 Status: Offline Sonork: 100.1661965 Thanks Meter: 195 | Quote:
Hello boro here is your file with out password free https://docs.google.com/uc?export=do...nBTanltUDhKSDA | |
The Following User Says Thank You to shanawas_1 For This Useful Post: |
03-01-2017, 13:46 | #6 (permalink) | |
Member: 2276949 Status: Offline Thanks Meter: 160 | Quote:
Thanks Bro But I Have Tested These All Files Same After Flash Blue Display | |
11-05-2017, 19:18 | #7 (permalink) |
Member: 2276949 Status: Offline Thanks Meter: 160 | Finally Blue Display FixDone After A Very Long Time Code: Scatter Load Ok , BaseBand : MT6580 , Project : d8058 , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : HOTWAV Device Model : d8058 Device CPU : MT6580 Device IntName : full_d8058 Device Version : 5.1 Device Compile : 8/26/2016 6:07:53 AM Device Project : ALPS.L1.MP6.V2_SUNV6580.WE.L_P11 Device ExtInfo : Venus_X10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 55 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100533130303034084CF12154B147 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 40001 [eMMC] : FLASH_CID : 700100533130303034084CF12154B147 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 [eMMC] : FLASH_UCP : 3648 MiB [eMMC 4 GiB] DEV RID : 0x034F20C9A51CE6D596760D3C1699C8D6 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : d8058 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3533 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000004320000 Erase : 0x00000000060A0000-0x00000000DCEE0000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_d8058.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0016 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : LOGO2 Image Flash Ok Flash now : LOGO3 Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:04:50 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : LOGO2 Verify Passed : LOGO3 Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:12 Reconnect Power/Cable! |
