03-19-2015, 20:45 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | MT6582 Dead Now im buyed Infinity activation and get mtk-module, When press get info or format, flash get this error: Operation : Check / Read Info [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001005631303030380655B9451CA16F DA Stat : v4.2 on BBID : 0x87 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:05 |
03-19-2015, 20:51 | #2 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 309 | Now im tried old version of mtk-tool and get this: Read info: Start at : [19/03/2015 / 13:25:47] Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001005631303030380655B9451CA16F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001005631303030380655B9451CA16F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND/eMMC init Mode Done! Elapsed: 00:00:14 But cant find how change Settings -> Other -> NAND/eMMC init Mode I dont have bin backup and cant write scatter file whit any box or software |
03-19-2015, 20:52 | #3 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 309 | When try fix download whit old version get this: Start at : [19/03/2015 / 13:42:11] Operation : Fix DL Errors [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001005631303030380655B9451CA16F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Phone not require that operation!!! Thanks for help if anyone can helpme to repair this phone. |
03-19-2015, 21:13 | #4 (permalink) | |
Junior Member Join Date: Aug 2006 Location: Tauranga,New Zlealand
Member: 338742 Status: Offline Thanks Meter: 3 | Quote:
The Following User Says Thank You to Drewsky For This Useful Post: |
03-19-2015, 22:53 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Next time advise take backups or use for format CM2. Otherwise - you will get more such headache... Now - to fix it need find original FW. No other way. Cm2 can readout extended info to determine it exactl , but you completely killed it. Now only seek correct. After you can flash it with CM2. |
03-21-2015, 02:46 | #10 (permalink) |
Member: 338742 Status: Offline Thanks Meter: 3 | megaDOTcoDOTnz/#!8QoCUYBa!XN3avLM1xXw26cOWtQXiv3_QFXcNJGCqbULzxV8 ahh0 Good Luck bro. |
03-23-2015, 02:16 | #12 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 309 | I found the Brand of this phone: Its Jiake N9100 JIAKE N9100 Android 4.4 Quad-core 3G Phone w/ 5.5" QHD, 1GB RAM, 8GB ROM, Wakeup, GPS, WiFi - Black - Free Shipping - DealExtreme https://www.youtube.com/watch?v=s0st_S9k44E |
03-27-2015, 21:18 | #13 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 309 | Finally Solved: Thanks to Pandawill user IcePW [ROM]Firmware for JIAKE N9100 Smartphone-sku63615 & sku63612 |
The Following User Says Thank You to bananin For This Useful Post: |
