Old 10-20-2016, 14:08   #1 (permalink)
Member: 2195859
Thanks Meter: 19
mt6582 imei repair
hi..i have one allview viper E ..by mistake i had reflashed another type/model inside phone .
after that..phone got dead/not powering on ..but detected in device manager and detected by cm2mtk module.
i had reflashed again using correct model fw.
phone is back alive..working ok, have baseband
the only problem is invalid imei , for both imei, this is a dual sim model.
i attach here log with read info log , repair imei error log ,and test check performed by cm2 software.
https://s11.postimg.org/613725m0j/im...irlogerror.jpg
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 51 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004B3758564D42012EF0DE66B1EB
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D42012EF0DE66B1EB
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x10CE1D8EF41569729B1FB5E01CD4394B
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : ALLVIEW
ProdName : ALLVIEW
ProdModel : V1_Viper_E
Device : ALLVIEW
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.KK1.MP1.V2.10
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_P11_1_wg_n
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Card found : S/N : 6898299C , v0134
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 51 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 4075 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BMVX7 , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 1501004B3758564D42012EF0DE66B1EB
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x40000000 , 1024 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1D
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:02:55
tried other usb..shorter cable.
i had other mtk phones..and i tried repair imei operations..and working..just this one give me problems.
thx in advance
Old 10-20-2016, 14:49   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Have you used a valid imei number? Erase full flash, reflash, write good NVRAM and try to repair again.
Br.
Infinity Box Support Team.
Page generated in 0.12176 seconds with 8 queries
