Old 08-02-2015, 06:52   #1 (permalink)
Muhammadsaqib11's Avatar
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 360
mt6582 make imei, make hard reset and imei goes to same previous
SM-G7102 come from abroad. both imei was same.
IMEI [1] : 358688000000158
IMEI [2] : 358688000000158
due to this when put sim card into the cell and power on it. it shows cross sign on signal portion.
i created orignal imei successfully.
Wait for phone...
Phone found! [ 12 ]
Sync...
Init Ok, waiting for phone ...
Reading initial info, wait...
Phone Info :
BB : MT6582, E01
HW : KEYTAK82_WET_JB5_HSPA_HW
SW : MOLY.WR8.W1315.MD.WG.MP.V23
MM : 2000.00.00
VR : 1.0
Security Info :
Read Ok!
Update IMEI[1] to : 355882052202621 done!
Update IMEI[2] to : 355882052202639 done!
Done!
Elapsed: 00:00:53
Reconnect Power/Cable!
problem solved but when we make hard reset to it after that imei goes to previous position.
how to solve it...........solution plz
full info log:
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004B4A5330304D03736C3DEC6FF9
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : M00SJ
[eMMC] : FLASH_CID : 1501004B4A5330304D03736C3DEC6FF9
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:12
Old 08-02-2015, 07:05   #2 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
will u tryed with cm2 permanat methode ?
http://forum.gsmhosting.com/vbb/f296...irway-1969991/
try it
Old 08-02-2015, 07:20   #3 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 360
try it
cant understand...........images hidden
Old 08-02-2015, 07:29   #4 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
check this is permanat method in 1.24 virsion
Old 08-02-2015, 15:35   #5 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 360
i did as you ask.........
permanent repair process completed successful.
Wait for phone...
Phone found! [ 12 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 358688000000158
IMEI [01] : 358688000000158
IMEI [02] : 358688000000158
IMEI [03] : 358688000000158
Set IMEI [00] : 355882052202621
Set IMEI [01] : 355882052202639
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 12 ]
Sync...
PostCheck Ok! Repair done!
Done!
Elapsed: 00:00:56
after this when power on cell shows a dim light only and off
then i formatted it
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Backup : Skipped by user request
FMT Mode set to : 2
Format : UserData Only (Factory Reset)
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:41
after format only show charging when insert charge but when power on the cell it only dead with battery.
i have its backup now i try to flash it but after flash same result. not power on only showing charging.
Operation : Flash [ v1.24 ]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : keytak82_wet_jb5 , Storage : EMMC
Setting : AFF verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E4C20000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_keytak82_wet_jb5.bin
Preloader Sent , Init passed
PartCount : 0014
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:02:49
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Verify Passed : FAT
Data Verify Done, time used : 00:00:47
Update RomInfo done
Done!
Elapsed: 00:04:04
any solution plzzzzzzzzzzzzzzz
Old 08-02-2015, 15:39   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Make fix BB first. Then check condition.
Old 08-02-2015, 15:56   #7 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 360
ooops......so sorry.
only battery was down therefore cell is not waking up.
sorry jaydi.........
now working fine
thanks to infinity team
Old 08-02-2015, 16:04   #8 (permalink)
JayDi's Avatar
Member: 462970
Seems as it down after the repair security process. If battery not enough - process will not end.
Anyway - next time just check battery
Page generated in 0.21993 seconds with 9 queries
