05-26-2015, 06:21 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Micromax A99 Imei Write Failed 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501005137585341420145A9E73712A3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 1501005137585341420145A9E73712A3 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A99 ProdModel : Micromax A99 Device : A99 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_TYD6582.WT.L_P8 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Repair Security [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong Reconnect Power/Cable! |
05-27-2015, 09:57 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Code: Device boot not done Check Drivers Try again | |
03-04-2016, 07:20 | #8 (permalink) |
Junior Member Join Date: Mar 2016 Location: Terakhongshangbi
Member: 2540255 Status: Offline Sonork: 100.1672434 Thanks Meter: 0 | Hi, I've Micromax A99 HW VerS2_05 S/W Ver:V1.16, the problem is Preloader is detected and Booting is done but it won't detect the CDC Driver. No sign of driver detection in Device Manager either, change USB Port, USB Cable, tried on different PCs no results... Pls Help me.. Thanks in Advance..!! |
03-07-2016, 07:18 | #10 (permalink) |
Member: 2540255 Status: Offline Sonork: 100.1672434 Thanks Meter: 0 | I think its phone problem because No device is detected in the device manager if the phone is turned on or if the screen lights up, but USB works fine when turn off.... |
