02-19-2015, 19:04 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | MT6589 no fully support!!! Wait??? Select: SPAutodetect[6171..6592]...NAND/ eMMC Code: Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Code: Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target Error : Correct DA sequence not found for target! SP SECURE Mode Enabled! Try select NORMAL SP Mode! Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Try many time, but same results Code: BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Please FIX.... >>MaO<< |
02-19-2015, 19:25 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. It is secure 6589 phone. CM2 support now : 6572 , 6582. Temporary way and not tested yet : Put this file in boot folder with change old one. Try again. Post result after. Please, also, check phone for SP lock ( locked or not ). |
03-17-2015, 14:30 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
03-17-2015, 14:34 | #6 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
