Old 03-16-2016, 09:46   #1 (permalink)
Registered User
Member: 2530239
Thanks Meter: 14
smart av failed samsung s6
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 103
AVVerify : Too much data! Break! Send report to support
Error! Check previous message for more info!
Check battery, cable, charge! Before try again, check result!
Operation Failed
Elapsed: 00:00:50
Reconnect Power/Cable!
Operation : Remove Viruses [SmartAV] [ v1.43 ]
SmartAV Conf : 100/80/2000
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 110100303034474530019F4616F25253
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 110100303034474530019F4616F25253
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 1677E2D457D95D40B0D2BCD90CF5CBA4
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Operation Failed
Elapsed: 00:00:48
Old 03-16-2016, 10:05   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
Scan with APP manager (with clear user data)
post result/logs.....
Old 03-16-2016, 10:08   #3 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
first factory reset phone
then again try smart AV
if not done use smart AV MANAGER
Old 03-16-2016, 10:34   #4 (permalink)
Registered User
Member: 2530239
Thanks Meter: 14
salam thnk very very very much syedtuqeer@shahabuddin problem solved
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
DDirect : Init Ok!
[User Select] : Remove Files and Garbage
[DDCleaner Info] : Files to remove : 38
[DDCleaner Info] : Additional garbage detected : 7
Removing files ...
[DDCleaner] : Removed 38
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : Clear UserData Ok!
Special Op #3 : PostFix Ok!
All Done!
Done!
Elapsed: 00:01:42
The Following User Says Thank You to mobileman2013 For This Useful Post:
Old 03-16-2016, 10:47   #5 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
happy to see u solved
Page generated in 0.15889 seconds with 8 queries
