GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   mt65xx restart is hardware or not full supported (https://forum.gsmhosting.com/vbb/f296/mt65xx-restart-hardware-not-full-supported-1867518/)
genci titi 2002 10-11-2014 08:04
what is wrong is problem hardware or not full supported
Card found: S/N 4D19:0128
Chinese Miracle II [MTK module] v 1.02
Operation : Format FileSystem [ v1.02 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582|8312_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 7001004D4D4330344758014B52CC1119
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C
[NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000
[NAND] : FLASH_LEN : 0x00000000
INT RAM : 0x00000000
EXT RAM : 0x00000000
BOOT TYPE : DONE
SOC VERIFY : 00
Boot Ok!
Error read initial info , blank flash or wrong settings?
Operation Failed
Elapsed: 00:00:25
Reconnect Power/Cable!
Dzirt 10-11-2014 11:49
Hello.
Does battery charged fully? It was disconnected by some reason during DA boot.
genci titi 2002 10-11-2014 16:56
Originally Posted by Dzirt (Post 10607551)
Hello.
battery is fully charged. my phone power on ,hang on logo and restart.
maybe need to flash it?
amancommunicati 10-11-2014 17:06
mobile model & co name
genci titi 2002 10-11-2014 17:24
1 Attachment(s)
DUAL SIM WITH SIM AND MICRO SIM
Syreni 500 MADE BY SZENI
GSM QUAD-BAND WCDMA
THIS IS MY PHONE
Smartphone Syreni IPS 500 - BullTech - Szenio
maomatrix 10-11-2014 18:24
MAYBE DRIVERS PROBLEM.....
Unistall and reinstall MTK android usb drivers.... and test again...
genci titi 2002 10-12-2014 08:30
Originally Posted by maomatrix (Post 10608357)
maybe drivers problem.....
Unistall and reinstall mtk android usb drivers.... And test again...
i try it but i have the same problem
Dzirt 10-12-2014 08:57
Try press and hold Vol+ and Vol- on powered off phone, and insert cable. During check/Identify.
genci titi 2002 10-12-2014 09:18
thank you mr. i try it but is the same condition..... maybe not supported or my phone have hardware problem? i try and re-try it more times
Dzirt 10-12-2014 09:29
Ok, 2-3 days need to find one-two more phone and check, if finds something wrong will improve all.
amancommunicati 10-12-2014 10:13
http://forum.gsmhosting.com/vbb/f296...error-1867688/
Dzirt 10-12-2014 10:26
@amancommunicati , maybe enough spam in every thread?
amancommunicati 10-12-2014 11:57
CM2MTKv3 - Download - 4shared
amancommunicati 10-12-2014 12:42
Dzirt sir ji thxxxxxxxxxxxxxx
genci titi 2002 10-18-2014 15:25
i try it now with new version and my phone conect and format ok but my phone power on and only restart
need to flash it? and if yes where can find flash file?
or is hardware problem?
Chinese Miracle II [MTK module] v 1.04
Operation : Format FileSystem [ v1.04 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0070 , OEM : 0100
[eMMC] : FLASH_INF : G40CM
[eMMC] : FLASH_CID : 7001004D4D4330344758014B52CC1119
[eMMC] : FLASH_LEN : 0x00000000E6800000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Backup : not found, will read now ...
Backup Ok
Repeat 'Format FS' procedure now!
Done!
Elapsed: 00:01:37
Wait for phone...
Phone found! [ 18 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Backup : Already exist
FMT Mode set to : 0
Format : UserData Only (Factory Reset)
Other : Set SpecFTM
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:26
Page generated in 0.13926 seconds with 6 queries
