10-14-2017, 17:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | MT6735 Error Code: Start at : [11-10-2017 / 12:09:31] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 51000115415358385BB5064267934FC6 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 15010051385853414206B55BC64FB267 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x24760925BD5C4B2F4A4E792174471162 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : GiONEE ProdName : F103 ProdModel : F103 Device : GiONEE_GBL7319 AndroidVer: 5.0 MTKxCPU : MT6735 MTKxPRJ : GBL7325GI_0203_T5970 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V2_P29_1_lwg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : imx135_mipi_raw CAM [1] : gc2355_mipi_raw MODEM : gionee6735_65c_l_lttg_dsds_cmcc gionee6735_65c_l_lwg_dsds_cmcc LOCALE : zh_CN en_US zh_TW Done! Elapsed: 00:00:12 Reconnect Power/Cable! Finish at : [11-10-2017 / 12:09:43] Start at : [11-10-2017 / 12:10:05] Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 51000115415358385BB5064267934FC6 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 15010051385853414206B55BC64FB267 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x24760925BD5C4B2F4A4E792174471162 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ========================= Start ========================= 11-10-2017 / 12:11:44 ========================================================= Card found : S/N : ********, v0136 Chinese Miracle II [MTK module] v 1.58 Start at : [11-10-2017 / 12:12:35] Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... |
The Following User Says Thank You to yuranc8 For This Useful Post: |
10-14-2017, 17:07 | #2 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | repair security at BOOT OK! freeze. Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Freeze too or not responding |
10-14-2017, 18:17 | #3 (permalink) |
Registered User Join Date: Oct 2011 Location: noshki balochistan pak
Member: 1669709 Status: Offline Sonork: 1654655 Thanks Meter: 163 | Cm2 not suport 6735 and team not working on mtk last 4 months |
The Following User Says Thank You to kifayatjan For This Useful Post: |
