08-06-2017, 11:06 | #1 (permalink) |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Mt6737 nokia 3 how to do anything with this ver CM MTK 1.58 this is NOKIA 3 Android 7 Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! |
08-30-2017, 17:20 | #6 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | What backup to make to be safe? Read nvram ? Read full flash? what to tick? -read factory file ? -pack images ? -read firmware info ? -read extra files ? I'm totaly new in CM so pleas help me I already read your announcement here |
08-31-2017, 11:41 | #10 (permalink) |
Member: 67805 Status: Offline Thanks Meter: 364 | First in the world :) easy than wiko read codes selected Code: Operation : SP Unlock [ v1.58 ] Mode : Read Codes 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A32890510526706183C [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A3936521005893C184467 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x72DAEA06540A0F1276D70C4607AB8DCF INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Slot[1] SIMLock Info : [1] Level , [Locked] : True , [Count] : 5 , [Spc] : 256 , [UnlockCode] : 0703692095896033 [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Slot[2] SIMLock Info : [1] Level , [Locked] : False [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following User Says Thank You to MOBICOM For This Useful Post: |
