10-22-2016, 17:36 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | Mt6755 flashing problem ======= Flash Files set for flashing : [ MCU ] : MT6755__OPPO__A1601__A1601EX_11_A.07_160715__Andro id_5.1.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A416574C5973CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xB20D25F4C2942E5F95F8DBAE93CC5958 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! USBDL : Init HSUSB Ok! ISPFF ID : 6755 , TARGET ID : 6755 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6755__OPPO__A1601__A1601EX_11_A.07_160715__Andro id_5.1.ispff Init Ok , Sending blocks ... Prepare failed Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:00:51 Reconnect Power/Cable! WHAT IS PROBLEM ? |
