08-07-2016, 15:14 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: suadt.com
Member: 235782 Status: Offline Thanks Meter: 82 | MT6755 read firmware factory ok - flash die phone Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from ScatFW! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A40E96E9085397 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x68D77D6DE362C2650608BB7C21B57807 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : oppo6750_15131 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Disabled M67BL : Skip HW_COMPATIBILITY_CHECK by User request! Checking and verifying PMT info M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000003F80000 Erase : 0x0000000004088000-0x0000000004000000 Erase : 0x0000000009800000-0x0000000001000000 Erase : 0x000000000AB00000-0x0000000002400000 Erase : 0x000000000D400000-0x00000007397FBE00 Flash Erase Done, time used : 00:00:03 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Failed! Region Finalize ACK not received! Empty battery or Cable problem? Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! |
08-07-2016, 15:25 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Because it secured one. Keep phone on hands. I work now on secure engine update for Helio line. ETA - 2-3 days. |
08-07-2016, 15:56 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SPFT will change nothing with this device as well. Send me in PM link to that preloader file from FW, please with CM2 AndroidInfo file from that fw. |
11-09-2016, 14:18 | #10 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: Bangadesh.Dhaka
Member: 694638 Status: Offline Sonork: no Thanks Meter: 164 | Quote:
Same to me Need help urgent | |
