12-15-2015, 15:41 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TUNISIA Age: 41
Member: 479816 Status: Offline Thanks Meter: 851 | MT8127 NAND not supported... i need read firmware for tablet with cpu MT8127 NAND but not done Chinese Miracle II [MTK module] v 1.39 Start at : [15/12/2015 / 15:04:12] Operation : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 71 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA04 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT8127_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 004500DE009400930076005000080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8D DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x004D , [MNAND] mNAND [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... #64 : Data CRC Error : 0000 , 5B06 Error while reading block! Something went wrong Done! |
12-16-2015, 06:29 | #3 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected JayDi Have a Suggestion... Quote:
For Example: Data CRC Error : 0000 , 5B06[/CODE]There is connection problem. If you like my suggestion then make a new thread otherwise delete my post. B/R Sheraz.... | |
01-26-2016, 12:48 | #4 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Romania Age: 53
Member: 83819 Status: Offline Thanks Meter: 12 | Chinese Miracle II [MTK module] v 1.40 Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 55 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA04 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT8127_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 004500DE009400930076005000080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8D DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x004D , [MNAND] mNAND [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... [Read Ok] : preloader_joyasz27_tb_c_mlc_kk.bi [Read Stop] : Unknow data! Make next steps : 1. Use WinRar or 7zip and rar this folder : MT8127__NAND__ 2. Send this archive with title "FWFACT" to [email protected] |
