03-31-2015, 16:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | MT8127 problem 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA04 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x00 BLVersion : 0xD8 Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v218.218 on BBID : 0x27 DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! |
03-31-2015, 16:28 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Don't press any key while connecting phone. And if phone is dead then you need to wait for update as Preloader Repair and Flash init and other operation for MT8127 will be supported in coming update. Br. | |
