04-07-2015, 09:18 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | MT8127 problem I want to flash an MT8127 tablet and it gives me this error. Operation : Check / Read Info [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! The tablet it's working, the battery in charged. |
04-07-2015, 09:24 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. It is Port/Driver problem. Use cable with direct connection to motherboard, no hub and e.t.c. Make HW reset on tablet - long hold PowerOn button ( up to 15 seconds ) with pressed VolUP and VolDown buttons. After - wait 15 seconds and connect phone with pressing before need operation button. If tablet have "Reset Button" - just press it once. |
04-07-2015, 11:47 | #8 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | Operation : Check / Read Info [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA03 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT8127_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 004500DE009400930076005000080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8D DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0048 , UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect failed [1F]! Send report to support! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:49 Reconnect Power/Cable! |
The Following User Says Thank You to decodari For This Useful Post: |
04-07-2015, 11:50 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hm... Thanks for the log. I need find such tablet with NAND. Without it - can't say something yet. I've found one with eMMC with much luck. Can you tell me model and any link, where is possible buy this sample? Or, if you can ship it to Russia or Dubai with any way and sell us - will be great. |
04-07-2015, 13:49 | #15 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Thanks for info. I can try order it via BY ( country in offcial diler list have one seller ) but it can take up to 2 month If you can help us with buy such device and send ( all taxes and e.t.c. will be payed too ) - maybe, can short time to 2-3 weeks. |
