Old 07-02-2018, 16:15   #1 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 165
mt8163 frp remove [SOLVED]
its ODYS pace 10 tab with mt8163
problem frp
first try press VOL UP conect cable
then VOL DOWN cable
then VOUP+VOLDOWN insert cable log is bellow
was try MT2 tool log is bellow
is any possible help to do frp this tab????
Card found : S/N , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 58 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BB_CPU_NME : [MediaTek] MT8163_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x97
NAND Flash : NOT INSTALLED
eMMC Flash : 450100444634303136010D4AB2323429
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0xBC000000
DRAM_INIT_REQ_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:08
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 58 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:09
Card found :
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4
Operation : Identify [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM58)
MODE : BOOTROM
PORT : 58
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT8163 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : LEGACY MTK
Info : Device is not supported yet!
Old 07-03-2018, 03:47   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Try this:
Load scatter with preloader first, then try to do usual FRP operation.
(attached to this post).
If you need factory signed firmware, download - HERE
https://firmware247.com
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 5 Users Say Thank You to Brka For This Useful Post:
Old 07-03-2018, 08:28   #3 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 165
Originally Posted by Brka View Post
Try this:
b.r.
Alex
use new mt2 or old cm2mt???
Old 07-03-2018, 08:50   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Use mtk v1.58 load firmware then make Frp
Old 07-03-2018, 08:59   #5 (permalink)
Member: 1273059
Thanks Meter: 10
archos 116 neon
BRKA-pleaz halp my bypass frp ARCHOS 116 NEON- THANKS
Old 07-03-2018, 10:12   #6 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 165
when i select given preloader scater
Card found : S/N : 7, v0136
[SCATCHECK] : Missing File : C:\Users\faz\Desktop\Odys_pace_10_preloader\lk.bin
[SCATCHECK] : Scatter wrong or incomplete. Use Factory or CM2MTK Scatter!
i was download full flash file and was select that file scatter its bellow msg.
[IMG]****************************/convkey/b8e4/xwgzsoc3387il8j4g.jpg[/IMG]
Old 07-03-2018, 12:57   #7 (permalink)
Member: 1273059
Thanks Meter: 10
scatter full flash----
Scatter Load Ok , BaseBand : MT8163 , Project : AC116NE , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Old 07-03-2018, 13:08   #8 (permalink)
Member: 1273059
Thanks Meter: 10
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:16
Old 07-03-2018, 13:23   #9 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
load scatter file
and connect with hold both volume buttons and repeat
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 07-03-2018, 13:54   #10 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 165
finaly i done it flash with official flash file i got it from support request, they gave me sp flash tool and flash file i was try with CM2mtk 1.58 select that file but its cannot boot but with that given sp flash tool flash done frp gone.
Old 07-03-2018, 15:27   #11 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Rename the scatter file to "MT8163_Android_scatter" and try again.
You can also select only preloader and proceed for required operation- Init Preloader - stop - Format.
Br.
Infinity Box Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 07-03-2018, 23:25   #12 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
You were given ALL you needed.
CM2 already told you what is the problem (strange directory name).
Also you were given correct flash file.
Next time, will not waste my time trying to help.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 09-11-2019, 17:22   #13 (permalink)
Member: 2035261
Sonork: alphatech
Thanks Meter: 6
can u pls share this file? i have one pace 10 with me also which i cant find the da file to remove frp...cm2 still gave error on this device
Old 09-11-2019, 17:24   #14 (permalink)
Member: 2035261
Sonork: alphatech
Thanks Meter: 6
about pace 1o
Share me file pls, i have one pace10 frp with me also
Old 09-12-2019, 10:07   #15 (permalink)
Member: 1043909
Thanks Meter: 60,926
pls check post #2 in current thread
Page generated in 0.23085 seconds with 9 queries
