07-02-2018, 16:15 | #1 (permalink) | ||
No Life Poster Join Date: Nov 2009 Location: sri lankan
Member: 1167260 Status: Offline Sonork: 100.1604772 Thanks Meter: 165 | mt8163 frp remove [SOLVED] problem frp first try press VOL UP conect cable then VOL DOWN cable then VOUP+VOLDOWN insert cable log is bellow was try MT2 tool log is bellow is any possible help to do frp this tab???? Quote:
07-03-2018, 03:47 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Try this: Load scatter with preloader first, then try to do usual FRP operation. (attached to this post). If you need factory signed firmware, download - HERE b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 5 Users Say Thank You to Brka For This Useful Post: |
07-03-2018, 08:28 | #3 (permalink) | |
Member: 1167260 Status: Offline Sonork: 100.1604772 Thanks Meter: 165 | Quote:
07-03-2018, 10:12 | #6 (permalink) | |
Member: 1167260 Status: Offline Sonork: 100.1604772 Thanks Meter: 165 | when i select given preloader scater Quote:
[IMG]****************************/convkey/b8e4/xwgzsoc3387il8j4g.jpg[/IMG] | |
07-03-2018, 13:08 | #8 (permalink) |
Freak Poster Join Date: Mar 2010 Location: ROMANIA
Member: 1273059 Status: Offline Thanks Meter: 10 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
07-03-2018, 13:54 | #10 (permalink) |
Member: 1167260 Status: Offline Sonork: 100.1604772 Thanks Meter: 165 | finaly i done it flash with official flash file i got it from support request, they gave me sp flash tool and flash file i was try with CM2mtk 1.58 select that file but its cannot boot but with that given sp flash tool flash done frp gone. |
07-03-2018, 15:27 | #11 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Rename the scatter file to "MT8163_Android_scatter" and try again. You can also select only preloader and proceed for required operation- Init Preloader - stop - Format. Br. Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
07-03-2018, 23:25 | #12 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
CM2 already told you what is the problem (strange directory name). Also you were given correct flash file. Next time, will not waste my time trying to help. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
