Old 10-16-2008, 11:11   #1 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
Pinfinder not detected, cant find adapter -- solution
Hi all
I have bad chinese phone with shortcut, pinfinder RED power led went off after connecting cable and after that.
Only green led on pinfinder was on and:
too many retries
cant find adapter
too many retries
cant find adapter
If your pinfinder is OUT of warranty or you simply dont have time to wait for send it to resseler cos you have big pile of phones to flash on your desk.
here is solution:
my damaged multiplexer was first from left, so if voltage on that blue points is NOT around 3.6 one of them or all in first row are damaged.
regards and maybe put this sticky
Sethxp
Seth
The Following User Says Thank You to Sethxp For This Useful Post:
Old 10-19-2008, 04:39   #2 (permalink)
tavoonly's Avatar
Member: 586318
Thanks Meter: 112
I have pinfinder module but the green light is not even turn on. I take the measures you say and what I get from these four points is 2.44 in all of them. So what else may I check in order to see what is right and what is wrong with module,
Thanks in advance.
BR,
Old 10-19-2008, 13:27   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@Sethxp
Thanks a lot for detailed instruction !
@tavoonly
At first check voltage at unibox pin-1, it should be +5v.
For more details check PinFinder manual page-20.
Old 10-20-2008, 10:31   #4 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
@tavoonly
so something is shorted.
solution, remove all 8 multiplexers and try to detect box without them.
Seth
Old 10-21-2008, 21:46   #5 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
Originally Posted by Sethxp View Post
@tavoonly
Seth
Do i have to change those components or what? Pls let me know
Old 10-22-2008, 04:40   #6 (permalink)
tavoonly's Avatar
Member: 586318
Thanks Meter: 112
I checked voltage in unibox and it was 0.05V so I did what it says in pinfinder manual and now it is working ok,
Thanks for your replies.
Old 10-22-2008, 08:02   #7 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
@kaino147
first, remove all multiplexers and try to detect box without them, if box is sucesfully detected, solder them back, one by one and try to detect box after each multiplexer you will find which is faulty. Multiplexer cost few cents. So if one or more is faulty, simply find which, buy it and change it.
reason why they go bad is that many phones dont have rx/tx in system connector and when you connect power wires and cable to phone, red power led will go off and some shorting happens that can damage multiplexer/s.
part number of multiplexer is
74HC4051 SMD
8channel analog.MX/deMX SO16
price is 0.52c circa
regards
Old 10-25-2008, 07:38   #8 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
In my case, pinfinder is detected and program opens fine but pinfinder can't detect phones and also when i press power on in software, normally the red led is supposed to come on and remains steadily on but mine doesn't come on at all. So what do i need to do in this case? Do i need to change all six multiplexers on pinfinder pcb? PLs let me know. Thanks in advance
Old 10-26-2008, 14:05   #9 (permalink)
Member: 130995
Hello,
If Power LED can not ON after you have pressed \"power\" button you do not need to change multiplexors.
It may be other reason, f.e. power circuit.
Please, check this schematic, it\'s power circuit. Please, check 2 transistors, probably one of it is damaged.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-28-2008, 22:50   #10 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
PLs infinity i must tell u i really don't understand this schematic! I really need need to know where the transistors are located on the pcb. so ill check and replace them immediately. I've almost given up on the pinfinder. PLs help out my situation
Old 10-29-2008, 03:54   #11 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
Originally Posted by InfinitySupport View Post
Hello,
Pls infinity help me out, I really don't understand the pic, i'll love th know which transistor to check so i can get it fixed. thanks will love a detailed picture. I dn't seem to understand the one above. Pls help thanks
Old 10-29-2008, 10:13   #12 (permalink)
Member: 130995
Hello,
PCB has only 2 transistors (small component with 3 legs), please, check it both.
Old 10-30-2008, 03:41   #13 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
Ok i've seen it, the problem is will i be able to find it to buy? I'll try and scout for it and post update on how far i've gone. thanks infinity.
Old 10-30-2008, 05:29   #14 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
Hello,
also use BC847 /equal transistor plz confirm no.s of that equal values transistor
Old 10-30-2008, 07:35   #15 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
Hello,
A little detailed pic, pls confirm which is correct the check and change
pinfinder not detected espoir1 Infinity-Box 3 12-23-2008 18:42
new pinfinder not detect Satyam321 Infinity-Box 7 09-26-2008 04:48
my pinfinder not detecting pinouts after update Deepakranasaria Infinity-Box 1 09-25-2008 22:05
I-Mobile CE0889 pinfinder not detect TUR@N ALAM Infinity-Box 1 08-17-2008 13:31
>>> My Pinfinder not Detecting Pin for Trend T786 >>> Faisal_Computer Infinity-Box 7 07-19-2008 23:48
Page generated in 0.22037 seconds with 10 queries
