Old 06-03-2008, 06:02   #1 (permalink)
Member: 201093
Thanks Meter: 15
MTK 6226 always pone lock code
COM11 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: user code
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:6485:84F3
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.03B997FD.[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN_D2B3956E].rpl
identification#1 detection finished
device-id: 03B997FD
identification#1 protocol ver: 04
ver. sw1: M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN
ver. sw2: M858dfxsp_6226b_11, 916A4C2D
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN]]...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN]_20080602-043543.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation...
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _03B997FD_M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXS P_6226B_11.BIN_D2B3956E_20080602-043630.B0X.bin
Finished, time used: 405 sec
Remove/Install battery now !
Action: unlock
Boot...
19200 fixed
Connecting, wait...
error: can't detect CPU id
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 6 sec
Action: unlock
Boot...
error: can't detect device
Boot Fail
Finished, time used: 5 sec
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: M858dfxsp_6226b_11
Version: M858_01
detecting structure #2...
0done
44 byte(s) read
imei: 13579024681122
connection Ok
detecting structure #1...
0done
145 byte(s) read
Phone lock: Off
Network lock: On
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
NP code: FF005566/FF005566
locked to: FFF-FF
NS code: FFFFFFFFFFC1C1C1/FFFFFFFFFF1C1C1C
NP of SP: FFF-FF
NP of CP: FFF-FF
Phone code: FFFFFFFFFF000000
Finished, time used: 14 sec
plz what can i do
i ffs 4 times but not work, also user lock code but not luck
Old 06-03-2008, 07:43   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
Hello,
make "format ffs", after this operation user code will be resetted to it's default value.
default codes: 0000, 1122, 3344, 1234
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 06-03-2008, 16:41   #3 (permalink)
Member: 201093
Thanks Meter: 15
not work phone have two cpu 6226 , 6205
Old 06-03-2008, 19:23   #4 (permalink)
Member: 148515
Thanks Meter: 15,715
hello!
even if phone has two MCU- lock code is keept in First (6226)
please read full flash and send it to [email protected]
with subject "lock code problem with <phone model>"
we will check situation
Old 06-13-2008, 06:21   #5 (permalink)
Member: 201093
Thanks Meter: 15
thanx for help but i have no high speed net
Old 10-29-2008, 15:03   #6 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 781
phone code cant removed???/
COM8 [VCP0] selected
module v2.66
Action: read codes
Model: Autodetect 6228, 6229, 6230 NAND
19200 autodetect
CPU: MT6226
chip: 0031:3636:96E9
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: M.RF4200228.M01001.V1.0.0.1M0406
Version: ML6227_HW
done
60 byte(s) read
imei: 35240900894681
connection Ok
warning: wrong packet cs
1 2 7 8 9 12 13 14warning: wrong packet cs
16 17 22 23 24 27 28 29error: detection failed (16 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 12 sec
Old 10-29-2008, 19:07   #7 (permalink)
Member: 148515
module v2.66
Action: read codes
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: ML6227_HW
done
60 byte(s) read
connection Ok
hello!
make format FFS complete
Old 10-29-2008, 22:06   #8 (permalink)
Member: 878435
Thanks Meter: 51
[quote=leomuns;3367288]COM11 [VCP0] selected
Device: Autodetect 6205-6227 NORhttp://www.****************.com
Action: user code
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
device-id: 03B997FD
ffs chip: 00
KUL I;LP
Old 10-30-2008, 07:56   #9 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 781
Done by formate [email protected] Thanks MAN
p9100 mtk 6226 sonuveene Chinese Models & Cloned Phones 0 03-11-2009 12:56
need pinout nokia 6110 navi 1sim mtk 6226 myponsel Infinity-Box 2 02-05-2009 18:26
help me!! telsda t812 flash file needed Mtk 6226 matnuacai Chinese Models & Cloned Phones 0 07-20-2008 06:17
N95 Mtk 6226 Mmc dj03p3z Chinese Models & Cloned Phones 0 05-10-2008 19:09
Help Me With MTK 6226 Dual Sim (N96i) White LCD minihack SpiderMan 3 04-28-2008 21:27
Page generated in 0.38121 seconds with 8 queries
