11-23-2010, 10:33 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Poland / England Age: 44
Member: 1196235 Status: Offline Thanks Meter: 27 | MTK 6253 Pin FINDER no bonus :( I `m useing Pin Finer 1. MTK62xx software version: 1.24 platform: MT: MT62xx (autodetect) cable type: 2x5 (L10C) mode: Slow searching adapter at COM4 (115200)... too many retries adapter found, version: 2000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 10, plain power/activation cycles: 1/7 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... failed to detect pins time required: 45 sec Trying to Power-On... Power is On 2. MT6205, MT6217-MT6235 software version: 1.24 platform: MT: MT6205, MT6217-MT6235 cable type: 2x5 (L10C) mode: Slow searching adapter at COM4 (115200)... too many retries adapter found, version: 2000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 10, plain power/activation cycles: 1/7 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... failed to detect pins time required: 45 sec Trying to Power-On... Power is On 3.CPU independent (autodetect) algorithm software version: 1.24 platform: CPU independent (autodetect) algorithm cable type: 2x5 (L10C) mode: Slow searching adapter at COM4 (115200)... too many retries adapter found, version: 2000 Loading platforms configuration... Initializing platforms... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. pins: 10, plain power/activation cycles: 1/5 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... PIN FINDER always STOPS on Rx:6 Tx:3 I was try use Rx:6 Tx:1,2,3,4,5,6,7,8,9,10 - no success When i try: Rx:6 Tx:3,4,5 ----> China miracle says COM4 [VCP0] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not boot device: 03E8:S_STOP error: last error: 03E8:S_STOP Disconnect... done Finished, time used: 13 sec Remove/Install battery now ! COM4 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! error: boot initialization step #2 failed: 20 error: boot initialization step #2 failed: 88 error: boot initialization step #2 failed: 00 error: boot initialization step #2 failed: 28 error: boot initialization step #2 failed: 07 error: boot initialization step #2 failed: 92 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: 16 error: boot initialization step #2 failed: 0F error: boot initialization step #2 failed: 80 error: boot initialization step #2 failed: 05 error: boot initialization step #2 failed: 3F error: boot initialization step #2 failed: E2 error: boot initialization step #2 failed: 00 error: boot initialization step #2 failed: 06 error: boot initialization step #2 failed: 42 error: boot initialization step #2 failed: FA error: boot initialization step #2 failed: 01 error: boot initialization step #2 failed: 04 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #3 failed: 20 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: 00 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #3 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: 00 error: boot initialization step #3 failed: 13 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: 00 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: 05 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 16 sec Remove/Install battery now ! What am i doing wrong ?? |
11-25-2010, 11:10 | #5 (permalink) |
Member: 1196235 Status: Offline Thanks Meter: 27 | i can`t red fullflash COM4 [VCP0] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not boot device: 03E8:S_STOP error: last error: 03E8:S_STOP Disconnect... done Finished, time used: 13 sec Remove/Install battery now ! |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
How to use Nokia tool - with connection 6-7 pin or not?.. | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-20-2000 19:53 |
PIC for lock 2 What pin for clock ??? | ondenuove | Nokia Hardware & Hardware Repair | 5 | 10-28-1999 08:49 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
