Old 11-09-2015, 10:58   #1 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Mtk 6260 flashing error with cm2 1.36 but done with 1.34:-
FLASHING LOGS CM2 1.36
Chinese Miracle II  [MTK module] v 1.36
Load File
File_Info   : R035_MMX_PCB01_gprs_MT6260_S00.R016_R035_MMX_X353_V011.bin
FileVersion : R016_R035_MMX_X353_V011
Load File Ok
Start  at : [11/9/2015 / 3:15:52 PM]
Operation : Flash [ v1.36 ]
======= Flash
Files set for flashing :
[ MCU ] : R035_MMX_PCB01_GPRS_MT6260_S00.R016_R035_MMX_X353_V011.BIN
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 28 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 1418395A2728E6FA8864CF34E149BFAB
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : 2C00 CB00 1800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128
[0] : FLASH_DIE : 002C 00CB 0018 0000
[0] : FLASH_LEN : 0x01000000
INT_RAM : 0x0000D000
EXT_RAM : 0x00800000
SDS_INFO : Not exists
Flash now
Erase region , wait ...
[ERROR] :
Write data , wait ...
[ERROR] : DONE
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:01:10
Reconnect Power/Cable!
FLASHING LOGS CM2 1.34
Chinese Miracle II  [MTK module] v 1.34
Load File
Load File Ok
Start  at : [11/9/2015 / 3:19:17 PM]
Operation : Flash [ v1.34 ]
======= Flash
Wait for phone...
Phone found! [ 28 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : DONE
[ERROR] : DA_BLANK_FLASH
Flash now
Write : R035_MMX_PCB01_GPRS_MT6260_S00.R016_R035_MMX_X353_V011.BIN
Done!
Elapsed: 00:01:23
PHONE RECOVERED WITH CM2 1.34
HOPE ALL THE BUGS WILL BE REMOVED IN FUTURE UPDATES.
WBR
sahil2000ind
Old 11-09-2015, 11:47   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
Post phone model/Condition ?
Try again with Fully battery( with V 1.36)
Because MTK 6260 Working good (QMobile E50)
Read
Operation : Check / Read Info [ v1.36 ]
Wait for phone...
Phone found! [ 59 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : C0A865957FF468C48DE42A45ED5FD74D
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : C200 2500 3600 0000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
EXT_RAM : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
Done!
Elapsed: 00:00:15
Operation : Read Flash [ v1.36 ]
Wait for phone...
Phone found! [ 59 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Reading Flash Conent now ...
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
File_Info   : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin
FileVersion : A8_D_YH_QMB_L2412_EUAP_V0.1.0
Saved to : C:\InfinityBox\CM2MTK\Read_out\BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin
Done!
Elapsed: 00:00:18
Write
Load File
Load File Ok
======= Flash
[ MCU ] : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin
Wait for phone...
Phone found! [ 59 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
Flash now
Write : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin
Done!
Elapsed: 00:00:50
Old 11-09-2015, 13:50   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
It because on some reason phone first erase attempt failed, but it finish it during process.
On second try all done. Not matter version, matter sequence.
Old 11-10-2015, 05:24   #4 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
i think ur right yesterday same failed here too
Old 11-10-2015, 06:49   #5 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
What same? Post logs .
Br.
Old 11-10-2015, 08:13   #6 (permalink)
JayDi's Avatar
Member: 462970
Time to ban idiots, I think.
Page generated in 0.16836 seconds with 8 queries
