10-01-2015, 16:11 | #1 (permalink) |
Freak Poster Join Date: Apr 2015 Location: pakistan
Member: 2373427 Status: Offline Thanks Meter: 43 | qmobile a10 not boot Infinty log Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Other box log Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:MT6577 Hardware version:CB00 Software version:E201 SecCfgVal :0x00000000 BromVersion :0xFF BLVersion :0x01 Boot downloading complete! EMMC_ID:0x90014A2058494E594816A15F65BC200D EMMC_PRODUCT_NAME: SAMSUNG :0x2058494E5948 EMMC_BOOT1_SIZE: 0x00200000 EMMC_BOOT2_SIZE: 0x00200000 EMMC_PRMB_SIZE: 0x00200000 EMMC_GP1_SIZE: 0x00000000 EMMC_GP2_SIZE: 0x00000000 EMMC_GP3_SIZE: 0x00000000 EMMC_GP4_SIZE: 0x00000000 EMMC_USER_SIZE: 0x0E7000000(3.61 G) |
10-01-2015, 16:29 | #3 (permalink) | |
Member: 2373427 Status: Offline Thanks Meter: 43 | Quote:
you right sir i try to correct cpu setting , mobile connect but with many try . but other box connect in 1st try log 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Check / Read Info [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A15F65BC200D [eMMC] : FLASH_EXT : 00200000/00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Fix Unknown BaseBand [ v1.32 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Operation : Fix Unknown BaseBand [ v1.32 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Fix Unknown BaseBand [ v1.32 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:01 Reconnect Power/Cable! Operation : Fix Unknown BaseBand [ v1.32 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Fix Unknown BaseBand [ v1.32 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A15F65BC200D [eMMC] : FLASH_EXT : 00200000/00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Repair Security [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Operation : Repair Security [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:01 Reconnect Power/Cable! Operation : Repair Security [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:01 Reconnect Power/Cable! Operation : Repair Security [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:01 Reconnect Power/Cable! Operation : Repair Security [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! | |
10-01-2015, 16:36 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Sorry, but I can't change anything in connection, because one fault for 100 users - not leave me chance determine problem. |
