06-15-2015, 08:54 | #1 (permalink) |
Banned Join Date: May 2012 Location: in ur heart Age: 32
Member: 1761678 Status: Offline Sonork: 100.1615439 Thanks Meter: 370 | mtk 6571 write flash not supported pls add this 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 227 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x10000000 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0082 , [SAMSUNG] KF98G16Q4X [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Break by user Done! Elapsed: 00:00:16 Reconnect Power/Cable! Load File Bad file detected! Load File Bad file detected! |
