10-03-2014, 13:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Mtk 6572 eMMC_ID : 7001004D4D4330344702031A19815089 Always stop in middle operation Voice mobile model v40 mtk6572 [ eMMC_ID : 7001004D4D4330344702031A19815089 ] always stop in middle on format option ,Hope will be fixed soon .Or may be i,m doing some mistake ,plz check and tell me exact fault ,what is going wrong by me . Code: Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Processing DA stage NAND_ID : 00000000000000000000 eMMC_ID : 7001004D4D4330344702031A19815089 DA Stat : v4.2 on BBID : 0x88 Code: Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Processing DA stage NAND_ID : 00000000000000000000 eMMC_ID : 7001004D4D4330344702031A19815089 DA Stat : v4.2 on BBID : 0x88 NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 NAND not supported yet :( INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Boot Error! Elapsed: 00:04:17 Reconnect Power/Cable! Regards amn32 |
10-03-2014, 13:57 | #3 (permalink) | |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
Regards amn32 | |
10-03-2014, 14:18 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Ok, thanks for info. How you connect it? Normally - it should connect just with insert cable in powered off phone, and insert battery. Phone will connect without preloder, if pressed Vol+/Vol- and powerOn keys. Try, please, connect with Vol+ or Vol- and check result. It will help me a lot in my research. |
10-03-2014, 14:28 | #6 (permalink) | |
Regards amn32 | |
