08-05-2015, 13:53 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Mtk 6572 Repair Imei Permanent very easy No need Root /Usb Debugg Code: Start at : [8/3/2015 / 12:47:56 PM] Operation : Repair Security [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051C79B79775165 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 11010030303447393051C79B79775165 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 35 IMEI [01] : 35 Set IMEI [00] : 35 Set IMEI [01] : 35 Prepare finished. Security check required! Wait for phone... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! Reconnect Power/Cable! Finish at : [8/3/2015 / 12:49:03 PM] Momin_Telecom |
The Following 2 Users Say Thank You to Momin_Telecom For This Useful Post: |
08-05-2015, 18:04 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | P.S. : always make post-check. It required for 100% result. Battery must be charged. If PC ask for some drivers - let me know, will update CM2 driver DB. |
