Old 03-31-2017, 18:42   #1 (permalink)
Member: 361348
Thanks Meter: 635
mtk 6797 repair imei fail
i av tried to repair imei mtk 6797 without success
Card found : S/N : A6C080ED , v0135
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 40 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6797
BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , R4BNJ
[eMMC] : FLASH_CID : 150100434A4E423452072979B237830F
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID : 0xDE96B4FF459971A4B9C827C3700B4D22
INT RAM : 0x00000000
EXT RAM : 0xC0000000 [3 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
IMEI [00] : xxxxxxxxxxxxxxxxx
IMEI [01] : xxxxxxxxxxxxxxxxx
Set IMEI [00] : xxxxxxxxxxxxxxxxx
Set IMEI [01] : xxxxxxxxxxxxxxxxx
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 40 ]
Sync...
Device boot not done
Check Drivers
Try again
The Following 3 Users Say Thank You to hippolyte85 For This Useful Post:
Old 03-31-2017, 18:55   #2 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 468
Driver problem. Install the drivers correctly
Sent from my C6833 using Tapatalk
Old 04-01-2017, 08:47   #3 (permalink)
Member: 361348
Thanks Meter: 635
plz can u tell me wich driver need to install?
Old 04-01-2017, 08:55   #4 (permalink)
Member: 2667438
Sonork: 100.1676500
Thanks Meter: 34
Android_Gadget_CDC_driver need
search google
The Following 2 Users Say Thank You to SaddamHosainSD For This Useful Post:
Old 04-01-2017, 09:21   #5 (permalink)
Member: 2514563
Driver problem or check basband info
Sent from my SM-N920V using Tapatalk
The Following User Says Thank You to yamanyousuf1999 For This Useful Post:
Old 04-01-2017, 09:21   #6 (permalink)
Member: 2667438
Sonork: 100.1676500
Thanks Meter: 34
here the link
http://forum.gsmhosting.com/vbb/f723...modem-1636173/
The Following User Says Thank You to SaddamHosainSD For This Useful Post:
Old 04-01-2017, 09:24   #7 (permalink)
Member: 2514563
Wait I'm uploading
Page generated in 0.16828 seconds with 8 queries
