Old 04-28-2019, 19:17   #1 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,533
MTK : AutomaticBoot select, User DB, Auto DB : How to use
1. User Config
1.1 : Select manual mode
1.2 : Select required file set
1.3 : Press SaveUser Config button
1.4 : Enter required data for easy locate after by default MT2 BootMenu
1.5 : Restart SW to accept new DB
2. Auto Config
2.1 : Select manual mode and fill required BootSet
2.1 : Press and hold Left CONTROL (CTRL) key on your keyboard, hold it, while press "IDENTIFY" button, wait till SW ask connect phone. Now you can release CTRL key. Connect device. Wait full boot.
2.2 : Since some devices uses different BottSet for different modes - you can add another type by same way
As you can see now both are in database.
3. Auto Boot Select
And most useful part - Automatic Boot configuration.
Take example from previous paragraph.
After we set files in p.2.1 and made DB update p.2.2 - SW determined that device is SECURED one and configuration allow do AutoBootSelect.
How it done? There is 2 way Learn SW do that :
1. Select configuration from DB and make Identify. If devices condition allow - it will be atomatically added in database.
2. Select manual mode and press LCTRL key during Identify. If devices condition allow - it will be atomatically added in database with new model info.
Since same configuration may be used under different brands and models ( for example - BQ and Wiko , Gionee and Fly and etc.... ) - next time, when you get another device on hands and inside it stored same secure scheme - SW will automatically pickup settings for it.
Our device after learn in PRELOADER and BROM mode connect now automatically :
Happy servicing
The Following 105 Users Say Thank You to JayDi For This Useful Post:
Old 04-28-2019, 19:43   #2 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 670
Really unique and very useful..
World's No.1 mtk service tool
The Following 3 Users Say Thank You to malka4u For This Useful Post:
Old 04-28-2019, 21:34   #3 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 106
Thank you thank you thank you thank you you are the best gsm in the world and i am so happy for this update
Old 04-28-2019, 21:36   #4 (permalink)
Member: 1356561
Thanks Meter: 69
thanks jaydi
it should be a video tutorial
Old 04-28-2019, 21:53   #5 (permalink)
Member: 1199489
Sonork: tarek
Thanks Meter: 2
:d:d:d tahnks teem
Old 04-28-2019, 21:53   #6 (permalink)
Member: 2218453
Thanks Meter: 45
TEST
FIRST
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06
Load IDBase v123080 Ok!
Operation : Identify [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM7)
MODE : PRELOADER PORT
PORT : 7
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6572
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00002001 : DA SEND ERROR!
  ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
  INFO : PRELOADER Level : Connect device in BROM mode!
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
PORT : 7
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : MTK_AllInOne_DA_SP.bin
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 484A019064314734A3018604ED319AC3
DAInf: 4 : 2 : 136
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 90014A483447316448601A3C39A31ED
        EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H4G1d
        EMMC:
              BOOT1  : 0x00200000 [ 2,00 MB ]
              BOOT2  : 0x00200000 [ 2,00 MB ]
              RPMB   : 0x00200000 [ 2,00 MB ]
              USER   : 0xE7000000 [ 3,61 GB ]
        SRAM: 0x00020000 [ 128,00 KB ]
        DRAM: 0x40000000 [ 1,00 GB ]
        CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 7B53FAA8AF5032D4F74EB4D8BF7BF5B5
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Done!
Elapsed: 00:00:28
USER CFG : MOBIWIRE : STARTRAIL5
SECOND
The Following 3 Users Say Thank You to BERCO For This Useful Post:
Old 04-28-2019, 21:57   #7 (permalink)
louka's Avatar
Member: 198016
Sonork: 100.1602918
Thanks Meter: 406
Thank you so match team of ininity you are the best gsm in the world and i am so happy for this update
Old 04-29-2019, 04:19   #8 (permalink)
Member: 2607653
Sonork: family members
Thanks Meter: 85
sir please make a video tutorial please
The Following User Says Thank You to jonny12345 For This Useful Post:
Old 04-29-2019, 05:18   #9 (permalink)
Member: 2812901
Thanks Meter: 333
The most beautiful in this update is auto select DB.
Old 04-29-2019, 05:58   #10 (permalink)
gsmgold_10's Avatar
Member: 1085634
Sonork: 1001650032
Thanks Meter: 45
JayDi sir if u don,t mind uplode a Video
Old 04-29-2019, 06:05   #11 (permalink)
Member: 2895066
Thank you... need full help
Old 04-29-2019, 07:04   #12 (permalink)
Member: 2166052
Sonork: 100.1678339
Thanks Meter: 45
Great Update .................
Old 04-29-2019, 07:21   #13 (permalink)
Member: 2883035
Thanks infinity team
But i think we need video tutorial so that we can able to make it and how to update firmware card to what you mentioned
Old 04-29-2019, 07:55   #14 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,333
Download dongle manager from support.
Old 04-29-2019, 08:07   #15 (permalink)
Member: 148515
Thanks Meter: 14,690
If your card firmware version is 0137 you don't need to update it again.
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Page generated in 0.48237 seconds with 7 queries
