12-07-2014, 21:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 38
Member: 882614 Status: Offline Sonork: 100.1608795 Thanks Meter: 141 | i8190 firmware i8190 restar with sim cart after remove sim phone normal Operation : Check / Read Info [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0065 , [TOSHIBA] TC58NYG0S8C [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
