Old 02-17-2017, 16:49   #1 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,313
Question MTK module (CM2MTK) need this feature in Futur Updat please
all uses of InfinityBox CM2MTK module need to add costimisation flash an read flash
to select specific partition to write an read for
for example : if user need to read protected partition (exp: protect1.bin or ftp.bin ....etc)
and if an user need to write only partion system (system.img ....etc)
if its possible in futur reply thinks great infinity team
all days you have unic and infinity of feature.
The Following User Says Thank You to rebainoor For This Useful Post:
Old 02-17-2017, 17:06   #2 (permalink)
.::Mosh@rof::.'s Avatar
Member: 1934602
Sonork: 100.1649323
Thanks Meter: 479
..::Hello Team::..
..::Hello Team::..
{~_~}::::::::::::::::::::::::::::::::::::::::::::::::::{~_~}
My Suggestion Is Add Team
Add ACI Q80 MTK-6580 READ & WRITE
Add All HUAWEI MTK-CHIP READ & WRITE
Add All OPPO MTK-CHIP READ & WRITE
Add All MEIZU MTK-CHIP
READ & WRITE
Add All XIAOMI MTK-CHIP
READ & WRITE
Add All CHINA SPD-6810+6820
READ & WRITE
..::& Must Be All Barand BootLoader Unlock Support::..
The Following 4 Users Say Thank You to .::[email protected]::. For This Useful Post:
Old 02-18-2017, 00:17   #3 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 149
@rebainoor, i'm pretty sure that this was the plan. They said that MemoryTool known from QML module will be also added into MTK module, quite possibly with next (v2?) update.
Currently, you can read any partition you want if you read flash into ispff file and then open it with for example FTK Imager or R-Studio. From there, you can just export a single partiton to an image. Flashing a single partition back is also possible but you need to modify scatter file for partitons like protect1 or frp as they should not be flashed in normal conditions.
The Following User Says Thank You to KrzychuG For This Useful Post:
Old 02-18-2017, 09:48   #4 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,313
yes its unic tool (memorytool) this is serious feature for advanced users
Old 02-18-2017, 10:14   #5 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,313
is not possible to edit or open ispff files with FTK Imager or R-Studio
Old 02-18-2017, 11:24   #6 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 149
Yes, it is, see attachments. In fact, they do work quite well and doesn't require R-Studio to scan the file to look for partitons. You can then create a byte-to-byte copy of a single partiton with R-Studio or user export disk image on specific partition in FTK Imager and you'll have a single partiton to work on later. Then, you can edit and upload it back to phone if needed and if you have proper scatter file that allows you to flash with addresses etc.
Old 02-18-2017, 12:37   #7 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,313
not read for my have tuto for open ispff with FTK image
Old 02-18-2017, 13:07   #8 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,313
Old 02-18-2017, 14:13   #9 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 149
What settings you used to read flash? It may be device dependant but the way i do it is by selecting "Pack images", "Read Info" and "Read Extra Files", this should produce complete image into ispff file.
Old 02-18-2017, 14:20   #10 (permalink)
Member: 2274875
Sonork: ?
Thanks Meter: 265
Yas Need All Brand MTK Bootloader Unlock Support... Bcz CM2 Was Called CM2 Is King Of The World So Why Still Many MTK CPU Unable To Unlock Bootloader Many More Thinks
Old 02-18-2017, 14:35   #11 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,313
its should tak few time many and many minutes to read
Old 02-18-2017, 14:50   #12 (permalink)
Member: 1968946
Thanks Meter: 97
Please add Meizu phones! Thanks!
Old 02-18-2017, 14:52   #13 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 149
Not sure if i understand you correctly, but yes, it should take a longer while since it also include userdata. Depeding on the phone, output file might be even 32GB in size (or more if there's bigger memory chip inside). With current version there's no way to read a single partition so that's the option you have. You can, alternatively, use read flash option from SP Flash tool if you know partiton start offset, it's length and have scatter and preloader file thatn can be used with that phone.
Old 02-18-2017, 15:02   #14 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,313
i proced to read new full dump now for test i wait to finish read dump (EMMC :16Go)
Old 02-18-2017, 15:40   #15 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,313
not possible with this setting may be you use old version of InfinityBox CM2MTK
Page generated in 0.42100 seconds with 8 queries
