Old 03-20-2009, 09:15   #1 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
MTK Phone Read Code Problem
@InfinityTeam
i've recieved one phone with user code but i'm not able to read the user code and software said there is new firmware detected and here i'm posting the link which include Full Flash + EEProm + Log File kindly download and if possible give me the USER code from the EEprom or Flash.
here is the link ::: DOWNLOAD :::
Take Care
ENJOY
Old 03-20-2009, 09:30   #2 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
safe format ur phone bro. TC
Old 03-20-2009, 09:54   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@imran_qasim
What is the problem with user code reading exactly ?
Did you tried to make "format ffs" ?
Old 03-20-2009, 10:20   #4 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Originally Posted by InfinitySupport View Post
@imran_qasim
==== log: [3/19/2009 5:14:01 PM] ==== COM94 [VCP0] selected module v2.77 Action: user code unlock method: smart fast Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F4C1:B64A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M988JRT_6226B_10G Version: M988_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 0 3 4 5 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29error: detection failed (27 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 157 sec Remove/Install battery now ! ==== log opened: [20/03/2009 11:39:35 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.77 S/N: Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [20/03/2009 11:40:01 AM] ==== COM5 [VCP0] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled Boot ... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 2 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [20/03/2009 11:40:32 AM] ==== COM5 [VCP0] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F4C1:B64A status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.81FD9374.[M988JRT_MULTI_JDFSLD1289_PCB01_GPRS_MT6226_S01.M98 8JRT_6226B_10G.BIN_AF902A84].rpl ==================== New firmware detected (v.2.77, database date: unknown): M988JRT_MULTI_JDFSLD1289_PCB01_GPRS_MT6226_S01.M98 8JRT_6226B_10G.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 81FD9374 identification#1 protocol ver: 04 ver. sw 1: M988JRT_MULTI_JDFSLD1289_PCB01_GPRS_MT6226_S01.M98 8JRT_6226B_10G.BIN ver. sw 2: M988JRT_6226B_10G, 7BD56F50 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[M988JRT_MULTI_JDFSLD1289_PCB01_GPRS_MT6226_S01.M98 8JRT_6226B_10G.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[M988JRT_MULTI_JDFSLD1289_PCB01_GPRS_MT6226_S01.M98 8JRT_6226B_10G.BIN]_20090320-114410.B0E.bin flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_81FD9374_M988JRT_MULTI_JDFSLD1289_PCB01_ GPRS_MT6226_S01.M988JRT_6226B_10G.BIN_AF902A84_200 90320-114428.B0X.bin Finished, time used: 232 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! check the log i try with Reading code with all method, i try format with save and complete but still there is code active. so this is the problem, i downloaded one flash file also which was not exact but compatible when i flash it goes white screen, then i flash it again with backup full flash and fone powered normally but code is still there and active. for complete detail u can check the log attached in the link which is posted in start. Take Care ENJOY
Old 03-21-2009, 05:33   #5 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Imran Please check this
http://forum.gsmhosting.com/vbb/show...&highlight=HUH
Faisal_Computer
D900i READ CODES Problem lazomi Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 10 06-16-2009 15:02
Phillips 655 Read Code Problem ? Formingus Easy-Unlocker 0 03-17-2009 11:46
Sagem Reading codes problem ! NokiaESN PolarBox 3 2 08-04-2008 19:34
D900 read code problem Kalidil Easy-Unlocker 5 07-23-2008 20:34
CVLE6 reading code problem kamransohail786 FuriousGold 4 10-10-2007 22:43
Page generated in 0.23305 seconds with 10 queries
