02-06-2016, 13:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Mtk secured phone ( warning the current network does not comply with this unit standard) And Here Is Infinity Log Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x05000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! Any Solution? |
02-06-2016, 13:47 | #5 (permalink) | |
Member: 2469611 Status: Offline Thanks Meter: 389 | Quote:
Here Is Logs Start at : [2/5/2016 / 6:26:08 AM] Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:31 Reconnect Power/Cable! Finish at : [2/5/2016 / 6:26:40 AM | |
02-06-2016, 14:23 | #8 (permalink) |
Member: 2469611 Status: Offline Thanks Meter: 389 | Model::ANBO AB001 And Here Is Log Without Pressing any Key Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Pressing Both Volume Keys Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154D533238100B004273A594DA DA Stat : v4.2 on BBID : 0x93 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Only Volume Down Key Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154D533238100B004273A594DA DA Stat : v4.2 on BBID : 0x93 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
