Old 07-09-2017, 08:50   #1 (permalink)
Member: 2325887
Thanks Meter: 134
Thumbs up why error?
Card found: S/N : 20B8AC71 , v0118
Registered to: hamid200
Connect phone on selected interface...
Core : v2.29 , NXP FlashEngine : v6.0
Flash Mode : Full Update (System, User, Boot)
Check and select files according selected FlashMode
Ok, Set : RM980_1.2.4.3_059T985_IMEA_IN_variant.img
Ok, Set : RM980_1.2.4.3_boot.img
Ok, Set : RM980_1.2.4.3_cache.img
Ok, Set : RM980_1.2.4.3_emmc_appsboot.mbn
Ok, Set : RM980_1.2.4.3_emmc_appsboothd.mbn
Ok, Set : RM980_1.2.4.3_fat.bin
Ok, Set : RM980_1.2.4.3_oemsbl.mbn
Ok, Set : RM980_1.2.4.3_oemsblhd.mbn
Ok, Set : RM980_1.2.4.3_persist.img
Ok, Set : RM980_1.2.4.3_preload.img
Ok, Set : RM980_1.2.4.3_qcsbl.mbn
Ok, Set : RM980_1.2.4.3_qcsblhd_cfgdata.mbn
Ok, Set : RM980_1.2.4.3_recovery.img
Ok, Set : RM980_1.2.4.3_system.img
Ok, Set : RM980_1.2.4.3_udisk.bin
Ok, Set : RM980_1.2.4.3_userdata.img
Dead Mode is Selected
1. Phone should be Off!
2. Press and hold 'Volume Down' button
3. Insert USB cable and hold button, until phone will be detected
Device boot not done
Check Drivers
Try again
Connect Ok
Get Phone Initial Info
HWDetails : 0x0000 , 0x0000 , 0x0000 , 0x0000
HWDetails : eMMC : VEN , OEM : , NAME :
HWDetails : Failed to identify!
File HW revision is : HW Revision V1
Processing : RM980_1.2.4.3_qcsblhd_cfgdata.mbn
Partition Init Not Done
Flash Error
Break flashing!
Phone disconected!
Old 07-09-2017, 11:01   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Re-install USB drviers.
Charge battery completely.
Close ALL Sw, which can use fastboot and adb ( managers and etc )
Then repeat operation.
Old 07-09-2017, 11:13   #3 (permalink)
Member: 2325887
Thanks Meter: 134
how to fast boot? adb
Old 07-09-2017, 11:17   #4 (permalink)
JayDi's Avatar
Member: 462970
Just open TaskManager and close all adb.exe and fastboot.exe, if they will be found in list.
Old 07-09-2017, 11:31   #5 (permalink)
Member: 2325887
Thanks Meter: 134
TaskManager adres taskmanager???
Old 07-09-2017, 11:43   #6 (permalink)
Member: 2325887
Thanks Meter: 134
plz send here driver thankss
Old 07-09-2017, 12:09   #7 (permalink)
JayDi's Avatar
Member: 462970
Drivers on support area. Whole package. Install all from it.
Page generated in 0.15422 seconds with 8 queries
