Voice Xtreme V75 4.2.1 MT6589 Code: Chinese Miracle II [MTK module] v 1.09 |
Intex y2 Pro Read Full Info Or Read Factory Firmware Done ;) Read Info Code: Operation : Read Flash [ v1.09 ] Read Flash Code: [Read Ok] : preloader_wt97057.bin |
Karbonn A19 Read Info Or Read Fully Info Done ;) Read Fully Info Code: Operation : Check / Read Info [ v1.09 ] Read Flash Code: Operation : Read Flash [ v1.09 ] |
Micromax A067 Read Info And Read Flash Done Read Info Code: Chinese Miracle II [MTK module] v 1.09 Read Flash Code: Operation : Read Flash [ v1.09 ] |
Testing latest beta CM2MTK 1.09 ... results: 2 Attachment(s) Alcatel OT-Pop C3 ( OT-4033X ) - MT6572 based = OK!!!: Code: Card found: S/N 0714:0xx8 Code: Operation : Read Flash [ v1.09 ] Under Win 7 - 32 bit: http://forum.gsmhosting.com/vbb/atta...1&d=1421073543 Same at WinXP - 32 bit: http://forum.gsmhosting.com/vbb/atta...1&d=1421073997 Anyway - FullFlash is saved at my CM2MTK readouts folder. Huawei Y511-U10 - MT6572 based = OK! : Code: Operation : Read Flash [ v1.09 ] Code: Operation : Read Flash [ v1.09 ] |
QMobile A51 Code: Operation : Read Flash [ v1.09 ] |
@debeliamark , thanks! Dump from this 6582 will help me a lot, download now. If possible, make also "debug log" - Other -> Make Debug log. It make problems seek more faster. MT6575/MT6577 will be supported also, for now I decide deactivate it. |
Qmobile i9 Read full info and Read factory Flash Done:) READ FULL INFO Code: Operation : Check / Read Info [ v1.09 ] Code: Operation : Read Flash [ v1.09 ] |
@Dzirt.. boss can you sendme a link to donwload this new version.. i have many many phones to test mt6572, 6571..etc Please can you??? Thanks in advance >>MaO<< |
@maomatrix , sent in PM. Will get few unsupported devices today and finish release version. |
Intex Cloud Y17+ Sucessfully read factory Firmware Read Full Flash Code: Operation : Read Flash [ v1.09 ] |
sir ji downlode link 1.09 |
Intex Aqua i6 read full info and factory firmware done- Card found: S/N Chinese Miracle II [MTK module] v 1.09 Operation : Check / Read Info [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D420128B4C29DA0EF DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420128B4C29DA0EF [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : Aqua ProdModel : Aqua i6 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : Intex_Aqua_i6_V13_indian Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D420128B4C29DA0EF DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420128B4C29DA0EF [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Aqua ProdModel : Aqua i6 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : Intex_Aqua_i6_V13_indian [Read Ok] : preloader_huaqin82_we_iba_jb5.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / huaqin82_we_iba_jb5 / EMMC FW Size : 934 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__Aqua__Aqua i6___4.2.2__Intex_Aqua_i6_V13_indian\ All done! Done! Elapsed: 00:05:07 Reconnect Power/Cable! No need of any mmc inside phone for reading factory firmware anymore, done at blazing speed:D Br. |
@debeliamark ,after 1 byte change it start working. Seems as new Alcatel will work well from now. Release follow after few hours. Code: Operation : Read Flash [ v1.09 ] |
