11-29-2015, 10:50 | #1 (permalink) | ||
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Is MTK6571 Secureboot phone SP unlock is supported ? Except listed Brands Quote:
Here is its info by Droid tool: Quote:
WBR | ||
11-30-2015, 02:41 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. I will add other universal unlock method with need of ADB and Root to avoid big delays, because in most cases not exists chance get such samples. |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
11-30-2015, 10:25 | #4 (permalink) | |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Quote:
Thanks Sir this is called real support .I tried to unlock it with ADB mode by another tool but the problem was its rooting neither the tool nor kingoroot and iroot could root the MTK6571 4.4.2 hope you add a better method of rooting too. WBR | |
01-14-2016, 11:17 | #10 (permalink) |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Again Received a MTK6571 secure boot locked hope Infinity team make a solution for unlock and read&write firmware of MTK secure boot phones . WBR |
01-30-2016, 08:19 | #11 (permalink) | |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Again received a MTK71 secure boot locked and waiting for its root and unlock solution . Quote:
03-02-2016, 07:35 | #13 (permalink) | |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Sir I Emailed its all details and CM2 info by latest update 1.41 to [email protected] 10 days ago with latest version. It can give info but says it is not locked but when put sim it says : The Current network does not comply with This Unit Standard! I wanted take its backup but Cm2 could read only preloader and some parts of its firmware I also attached the read part to support . Sir I am still waiting for its result many this phone are waiting for your solution . Quote:
WBR | |
05-16-2016, 13:00 | #14 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | HEPI T61, same problem Same problem with HEPI T61, has solution? Or this problem with TD-CDMA china phones? Code: Chinese Miracle II [MTK module] v 1.47 Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 1501004E4A325A4D420221E3F2EB13A9 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZ2J [eMMC] : FLASH_CID : 1501004E4A325A4D420221E3F2EB13A9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 91E175FAEF8EBC4A607B96183F22A4FB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : top71_et_kk ProdModel : MT6571 Device : top71_et_kk AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1.22 SECURITY : IMEI_SW [1] : 850765001022978 IMEI_SW [2] : 850765001022978 BTMAC Addr : C69E466571C4 WiFi MAC : 000000000000 MODEM : BaseBand : MT6571_S00_MOLY_WR8_W1328_MD_TG_MP_V33_P1_1_tg_n EXTRA : LCD [0] : lcm_common LCD [1] : #fl10801_qhd_vdo LCD [2] : #nt35510_dsi_vdo_6571 LCD Res : 854x480 TOUCH [0] : GT9157 TOUCH [1] : msg2238 TOUCH [2] : GSL1688 TOUCH [3] : ft5206 TOUCH [4] : #gslx680 TOUCH [5] : #GT9XX CAM [0] : gc2235_mipi_raw CAM [1] : gc2355_mipi_raw CAM [2] : gc2035_mipi_yuv CAM [3] : gc5004_mipi_raw CAM [4] : gc2755_mipi_raw CAM [5] : ov5693_mipi_raw CAM [6] : s5k4ecgx_mipi_yuv CAM [7] : s5k4e1ga_mipi_raw CAM [8] : gc2145_mipi_yuv CAM [9] : gc2155_mipi_yuv CAM [10] : gc2355s_raw CAM [11] : gc2235s_raw CAM [12] : gc0328_yuv CAM [13] : gc0329_yuv CAM [14] : gc0308_yuv CAM [15] : gc0309_yuv CAM [16] : gc0311_yuv CAM [17] : gc0312_yuv CAM [18] : ov5648_mipi_raw CAM [19] : jx507_mipi_raw CAM [20] : ov9760_mipi_raw CAM [21] : gc0310_mipi_yuv CAM [22] : hm2056_mipi_yuv CAM [23] : ov5647_mipi_raw CAM [24] : ov5670_mipi_raw CAM [25] : bf3905_mipi_yuv CAM [26] : hm8131_mipi_raw CAM [27] : hm5040_mipi_raw CAM [28] : hi545_mipi_raw CAM [29] : sp5409_mipi_raw CAM [30] : sp2508_mipi_raw CAM [31] : gc2145s_yuv CAM [32] : sp0a19_yuv CAM [33] : gc0409_mipi_raw CAM [34] : ov2680_mipi_raw CAM [35] : ov9762_mipi_raw CAM [36] : hi256_mipi_yuv MODEM : VC7594-31 LOCALE : zh_CN en_US zh_TW hdpi Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read NVRAM [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 1501004E4A325A4D420221E3F2EB13A9 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZ2J [eMMC] : FLASH_CID : 1501004E4A325A4D420221E3F2EB13A9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 91E175FAEF8EBC4A607B96183F22A4FB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6571_S00_MOLY_WR8_W1328_MD_TG_MP_V33_P1_1_tg_n NVM Read Ok, Hepi T61 MT6571_S00_MOLY_WR8_W1328_MD_TG_MP_V33_P1_1_tg_n_eMMC.spnv Done! Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Read Flash [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 1501004E4A325A4D420221E3F2EB13A9 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZ2J [eMMC] : FLASH_CID : 1501004E4A325A4D420221E3F2EB13A9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 91E175FAEF8EBC4A607B96183F22A4FB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : alps ProdName : top71_et_kk ProdModel : MT6571 Device : top71_et_kk AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1.22 [Read Ok] : preloader_top71_et_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : hwinfo.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6571 / V1.1.1 / top71_et_kk / EMMC Android Info saved FW Size : 726 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6571__alps__MT6571__top71_et_kk__4.4.2__ALPS.KK1.MP7.V1.22\ All done! Done! Elapsed: 00:04:20 Reconnect Power/Cable! |
05-24-2016, 09:07 | #15 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | I was try repair security, don't help Problem not solved. Code: Operation : Repair Security [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 1501004E4A325A4D420221E3F2EB13A9 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZ2J [eMMC] : FLASH_CID : 1501004E4A325A4D420221E3F2EB13A9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 91E175FAEF8EBC4A607B96183F22A4FB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 353226********* IMEI [01] : 353226********* Set IMEI [00] : 850765********** Set IMEI [01] : 850765********** Prepare finished. Security check required! Wait for phone... Phone found! [ 136 ] Sync... Repair done! Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
The Following User Says Thank You to Abzal For This Useful Post: |
