04-30-2018, 09:50 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | MTK6572 IMEI write failed 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 359891061044854 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:05:23 Reconnect Power/Cable! i dont have nvram for this phone any suggestions? here is info Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344731640405250011419293 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A48344731640405250011419293 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x39794C9A0093AC0AEE6DBEC560B7469D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Samsung ProdName : SM-J710FN ProdModel : SM-J710FN Device : j7208 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : J7208_6.0.1_V1.7 20161027-1530 SECURITY : IMEI_SW [1] : 359891061138565 IMEI_SW [2] : 359892061138563 BTMAC Addr : 000046657201 WiFi MAC : 000000000000 EXTRA : LCD [0] : nt35521_j7208_dsi_vdo LCD Res : 1280x720 TOUCH [0] : ft5206_new CAM [0] : s5k4ecgx_yuv CAM [1] : gc2035_yuv CAM [2] : hi253_yuv CAM [3] : hi253_sub_yuv CAM [4] : gt2005_yuv CAM [5] : gc2145_yuv CAM [6] : gc2155_yuv CAM [7] : sp0a19_yuv CAM [8] : sp0718_yuv CAM [9] : gc0329_yuv CAM [10] : gc0308_yuv CAM [11] : gc0328_yuv CAM [12] : gc0309_yuv CAM [13] : gc0307_yuv CAM [14] : bf3a03_yuv MODEM : keytak72_wet_jb3_hspa_band15 LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR pt_PT fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG fa_IR th_TH km_KH my_MM el_GR hdpi xhdpi -sw320dp -sw600dp -sw720dp Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following User Says Thank You to nomi_42us For This Useful Post: |
04-30-2018, 10:11 | #4 (permalink) | |
Insane Poster Join Date: Jun 2014 Location: Kumarkhali.Kushtia Age: 35
Member: 2211420 Status: Offline Sonork: 100.1651090 Thanks Meter: 32 | Quote:
04-30-2018, 10:25 | #5 (permalink) |
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | i am not in volcano section so need solution from cm2. BTW i tried and failed and i havent posted it there because i know they wont give any solution(team is not good at it) so i posted here because i know here my problem will be solved |
04-30-2018, 10:38 | #10 (permalink) |
Freak Poster Join Date: Jul 2016 Location: phillipines
Member: 2596094 Status: Offline Thanks Meter: 83 | heres direct link https://www.needrom.com/download/11-...016-sm-j710fn/ |
04-30-2018, 10:40 | #12 (permalink) |
Member: 2596094 Status: Offline Thanks Meter: 83 | https://www.needrom.com/download/11-...016-sm-j710fn/ you need an acount to log in |
