mts s189 unlock problem?(Answered 14 August 2011) i've mts samsung s189..unlocking showing done but when insert other ruim then show invailed card plz tell me any body unlocking possible with great infinty dongal or not? ver is mv mr02.... |
first you have to flash mts samsung s189 with samsung pst flash files is given in these foru m and when flashing is complete now unlock with infinity |
Check http://forum.gsmhosting.com/vbb/f633...nuals-1029092/ Wbr <<<Megatron>>> |
Really Pls check Again :) Last edited by Infinity-CDMA; 07-19-11 at 11:29. Reason: MODELS UPDATED Wbr <<<Megatron>>> |
Link Is Here http://forum.gsmhosting.com/vbb/f633...nuals-1029092/ And Last Edited Shows When Post Was Modified So It Was Last Month New 189 Not Unlock Just Because Its Not Supported Wbr <<<Megatron>>> |
can you post the logs of the unlocking done...i think it didnt work out properly.... first use back uart cable and then select mts s189 and click on unlock....it works for me brother... |
2 Attachment(s) [QUOTE=rahul_rocks3;7625422]can you post the logs of the unlocking done...i think it didnt work out properly.... first use back uart cable and then select mts s189 and click on unlock....it works for me brother... dear chk it again ur handset ver MRM02? any way log pic here....& also chk here......Mts s189 new version unlock file - Cdma Gsm Forum Mygsmindia. |
1 Attachment(s) ohhh sory wrong pic ok pic here... |
Dear Pavi May be Your Phone is new version !! Quote:
Most of Samsung Models are Designed with CMD commands and it work .If your phone not get unlocked with Normal CMD then there must be New version .To Make support to it we need firmware ,dll ,flasher of the That model. If you can provide its good .If you can't then must wait till we found and do Rnd . We never Hide anything from our End User. If you want to unlock in urgent Search forum and try to understand how people either downgrade or Cross flash this phone . We not support this Phone MTS 189( one version) for Direct-Unlock. Regards |
Still for your help i have enclosed the flasher and flash file to change the model of ur handset so that it can be unlocked..... Open Samsung PST select S189, select emergency mode...select the flash file and flash your handset....then when the flashing is completed simply unlock using B189 or B159 method.....try it will surely work. samsung s189 new.rar - 4shared.com - online file sharing and storage - download Note : The file is tested by me but do it at your own risk because many times while flashing it gets stuck at 2% and that can cause your handset to be dead |
simply best infinity............... |
