my 220x succ unlock whit infinity ;-) COM5 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sta_20080420-144210.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sec_20080420-144213.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-complete_20080420-144219.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 43 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
successfully unlocked my220x COM14 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sta_20080429-134717.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sec_20080429-134723.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-complete_20080429-134729.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 46 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
All is ok with sagem phones And we hope that vodaphone v716 will be supported in the near future. |
Infinity You are the best!!! 220x from first shoot... UNLOCK First I try witch SMTi and no results... Second Infinity and he make it :) |
when i tried to unlock my sagem with the code12345678 the pnone tell me is wrong coe what can i do |
All of the above has compleatly confused me. I want to unlock my sagem my220x but I don't know how. Please help me. |
Just run Infinity-Box software, connect cable to phone, go to software \"Service\" page and press \"unlock\" button. Now follow the instructions given by software |
Hi thanks for the reply. I can see infinity-box at the top of this page :), but what cable are you ref. to please? I'm not sure about that, but there's only one cable running from my computer and that's the internet lead :confused:. I went nto intinity-box, but there wasn't a post titledservices :( Cheers :) |
Just run Infinity-Box Shell, select required model and you will see detailed cable/pinout information. More information is here: http:///vbb/showthread.php?t=526956 |
